water pump
- Isuzu vehicle(s): 1984 s10 2.2 Isuzu Diesel motor
water pump
Greetings friends! My water pump has went out in my 84s10 with the diesel engine:( Would a Isuzu Pickup diesel same year water pump fit it? If not where are you guys finding water pumps
- puttputtinpup
Re: water pump
I'll forward this to someone by PM that is familiar with the S10 diesel. I seem to remember that the water pumps are different, but not 100% sure.
- puttputtinpup
Re: water pump
Here's a couple of pictures of the S10 c223 and rock auto website of an isuzu pup c223.
S10
As you can see, they look different
- Isuzu vehicle(s): Factory 1985 S10 2.2 Diesel, 1989 Isuzu 4x4 2.2 Turbo Diesel, 1999 Chevy Suburban 6.5 Turbo Diesel
Re: water pump
The GM 2.2 diesel water pumps are GM specific, they are totally different from the Isuzu 2.2 pumps. Not sure who or where you can find rebuilds or new but will be $$, good luck & report back what you find. Thx
- Isuzu vehicle(s): Pup Trooper Rodeo
Re: water pump
Mitsubishi 4s series diesel engines found in Cat, Hyster and Mitsubishi ForkLifts is the same pump. Readily available just about anywhere.
Re: water pump
Same pump as what? If it's indeed the same as the S10, you will be a superhero here with the S10 owners.isuzu Specialities wrote: ↑Tue Aug 13, 2024 3:32 pm Mitsubishi 4s series diesel engines found in Cat, Hyster and Mitsubishi ForkLifts is the same pump. Readily available just about anywhere.
Please post the link.
Thanks.
Re: water pump
JoeIsuzu wrote: ↑Tue Aug 13, 2024 4:11 pmSame pump as what? If it's indeed the same as the S10, you will be a superhero here with the S10 owners.isuzu Specialities wrote: ↑Tue Aug 13, 2024 3:32 pm Mitsubishi 4s series diesel engines found in Cat, Hyster and Mitsubishi ForkLifts is the same pump. Readily available just about anywhere.
Thanks.
Its been about a year sense i have installed one on a customer's vehicle. The marine version of Perkin's 404c water pump part #998-456 come to mind but not 100% sure if this is the one I have used many times before or not. You will need to install a 45 deg hose fitting into the pump housing to accommodate the heater bypass. This same engine has many Industrial, Marine and Stationary use variants branded Daihatsu, Kawasaki, Caterpillar and Mitsubishi. Look at these models if the one I recommended doesn't fit.
