When you break a blend door
genericusername
Isuzu vehicle(s): 1993 Pickup, 2.3l 4zd1
Post by genericusername »
So a 10-24 socket head cap screw with a flat careful ground in it will fit in the blend door linkage
I used a rotary tool with a burr to start a pilot hole in the broken blend door arm. Drilled and tapped it. Worked way better than the super glue
I only thought about taking pictures after I got done, but hopefully that is clear enough. I actually broke 2 and aside from needing to buy a right angle attachment to drill one (steering column was in the way) I was able to do with most everything in place.
