So if you've used different oils in your Pup's diesel engine and manual trans, and noticed any differences, please copy and fill out this template, and reply here.
Oil brand and model:
Nominal viscosity:
Type:
Years used:
Miles on engine:
Change interval:
Oil consumption:
Cold performance:
Warm performance:
Other comments:
I'd start, but I just started using my Pup so I haven't experienced different oils. Instead, I'll do an example based on my BMW 544iT:
Engine
Oil brand and model: Castrol Edge
Nominal viscosity: 5W30
Type: full-synthetic
Years used: 2011ish, again in 2015-16
Miles on engine: ~170k first time, ~200k second time
Change interval: about 11k both times
Oil consumption: negligible
Cold performance: unremarkable
Warm performance: unremarkable
Other comments: turned a light-medium brown by 11k, and both times had lifter issues after sitting for some weeks.
Oil brand and model: Amsoil Euro
Years used: 2012-14, 2016-17
Miles on engine: varied 180k-210k
Change interval: 11-14k
Cold performance: unremarkable... which is remarkable at -16C one winter
Warm performance: engine somehow sounds and feels a bit smoother than usual
Other comments: was still quite light by 14k. Never heard lifter tick. Subjectively, the best oil I've used.
Oil brand and model: Mobil 1
Nominal viscosity: 0W40
Years used: 2010, 2018
Miles on engine: 156k, then ~220k
Change interval: 10k+
Oil consumption: about 1 quart (out of 8) after 10k miles
Cold performance: not really tested
Warm performance: feels a touch smoother than the Castrol, not as good as the Amsoil
Other comments: gaskets were a bit weepy after switching to it. Seems a good oil otherwise.
Transmission
Oil brand and model: Royal Purple Synchromax
Nominal viscosity: ??
Years used: 2010-2018
Miles on engine: 156k-210k
Change interval: three-ish years
Oil consumption: none
Cold performance: really stiff shifting required double-clutching. Bearings seemed ok.
Warm performance: mediocre shifting, but zero bearing noise.
Other comments:
Oil brand and model: Redline MTL
Nominal viscosity: 75W80
Years used: 2018-22
Miles on engine: 210k-230k
Change interval: haven't changed yet
Cold performance: good, a bit stiff.
Warm performance: excellent. Still no bearing noise, and a lot slicker synchros than with the Purple.
Other comments:
