THIS IS FOR ANYONE PLANNING ON COMING TO OUR GET TOGETHER IN OCT,
FIRST BRING SOME FOLD UP CHAIRS
SECOND I AM GETTING READY TO SEND OFF A BUNCH OF VLV TAPPETS ,/LIFTERS TO HAVE MACHINED AND ALL SO ROCKER ARMS, IF A ANYONE HAS ANY THAT THEY WOULD LIKE TO HAVE MACHINED TO LOOK AND PERFORM LIKE NEW BRING THEM WITH YOU AND THEY CAN GO IN MY ORDER AND THEN I CAN SHIP THEM BACK TO YOU, THE PLACE THAT DOES THEM DOES NOT LIKE TO DO A FEW AT A TIME , THE MORE THEY CAN DO THE CHEAPER IT IS , THE ROCKER USUALLY RUN ABOUT 6-7 DOLLARS EACH AT LEAST THAT IS WHAT THEY WERE LAST YEAR AND THE TAPPETS ARE ABOUT 4-5 DOLLARS EACH, AND THEY LOOK LIKE NEW , THE DO NOT RE BUSH THE ROCKERS SINCE THEY RARELY NEED THAT, JUST SURFACE THE TIPS , CAMSHAFTS RUN ABOUT 150 EACH TO GET REGROUND , JUST BRING ALL YOUR OLD ONES IF YOU HAVE ANY , I HAVE CORES FOR THE SMALL PARTS BUT NONE FOR THE CAMS RIGHT NOW . THESE PRICES ARE ABOUT HALF THE PRICE OF NEW PARTS WHEN AVAILABLE, JERRY
PARTS
Re: PARTS
If this is gonna be the parts thread does anyone have a Bumper and turn signal?
1986 2.3L 5 Speed Spacecab LS 260,000miles still running ready to die! Knocking smoking Sold!!
1984 Pontiac Firebird Trans-Am 305 HO with 700R4 Motor just dropped in and its dead
Re: PARTS
I have front bumper in black and a rear one in black. Turn signal I will have too I believe. Will check when I get home. Lemme know which bumper you need. Tks
___________________________________________
Was 81 now 87 Diesel Pup 2WD 5-Speed - Running SVO
94 F350 7.3 Stroker 2WD Flatbed - Running B100
00 VW Jetta TDI - Running B100
05 3400 Kubota Diesel Tracor - Running B50
- puttputtinpup
Re: PARTS
Don't forget the yoke, Joe.
Jerry, I have Larry Quick's old injectors. Could you show me how to do a popoff test while we're there if there's time?
Andy
Andy
Re: PARTS
I just need a front bumper as you can see in my news thread from where i was forced to take down a speed limit sign at 60mph.
Re: PARTS
I'm in need of the vacuum idle advance that's mounted on the back of the IP if anyone has one. I just found out today that it's open. I sucked on the hose and it acted like there was a LARGE hole in it. I'll planning on getting to Jerry's around 10 and staying for a few hours before heading back to central SC.
Gerald K4NHN
Cayce, SC
Gerald K4NHN
Cayce, SC
Gerald K4NHN
Cayce, SC
"One test is worth a thousand opinions"
1983 LS DIESEL LONG BED 2 W/D 126K miles
1986 LS Trooper Tubro Diesel 4 W/D 186K + miles SOLD
Cayce, SC
- Official Sensei, IsuzuPup Dōjō
Re: PARTS
puttputtinpup wrote:Don't forget the yoke, Joe.
Andy
YES NO PROB, JERRY
Re: PARTS
Does anyone have a heater core? My '84 Diesel is leaking in the cab. Jerry, I've bought parts from you before, although it's been awhile. I'm in northeast Georgia - Cornelia.
Thanks
candlejohn
Thanks
candlejohn
