Stuck Odometer Repair
Topics that are not specific to diesel or gasoline engines.
90pupdiesel
Post by 90pupdiesel »
I ran into a problem this week with my odometer that isnt really a bad thing. Now that i'm back to school I have been putting alot of miles on ~500 a week and have been running alot of wvo. The problem that i encountered it that my trip meter doesn't last for a hole tank of diesel, because it only has digits to 999.9 miles. So after that it just rolled on over with still about 1/2 a tank of diesel. I just wondered if anyone else had this "good problem" or if any of the pups from the 80's even got trip meters.
Jordan
Reason: Moved this to the "How-To" section, and it needed an appropriate "Subject"
ddcuning
Isuzu vehicle(s): 85 GMC S-15 Diesel
Re: A good problem
Post by ddcuning »
I ran my GMC S-15 (with Isuzu Diesel) 430miles this week and used 2 gallons of B100 which I buy. The rest was on WVO.
Dave C
Re: A good problem
90pupdiesel wrote:I ran into a problem this week with my odometer that isnt really a bad thing. Now that i'm back to school I have been putting alot of miles on ~500 a week and have been running alot of wvo. The problem that i encountered it that my trip meter doesn't last for a hole tank of diesel, because it only has digits to 999.9 miles. So after that it just rolled on over with still about 1/2 a tank of diesel. I just wondered if anyone else had this "good problem" or if any of the pups from the 80's even got trip meters.
Jordan
The problem with your odometer is typical of the mid 80's Pups. I'm not sure about yours being a 90 model. The numbers that turn, rotate on a shaft that had been grease, but over time gets gooey and stiff. My 82 just started this problem at 262000. I have to take it apart, spread the numbers apart a little and spray some wd40 in there.
Here's a picture of the inside of an 81 speedometer head:
Re: A good problem
Andy, he's saying it IS working...the trip meter just doesn't have enough digits to last a whole tank of diesel because he's using WVO (from 2nd tank, I assume).
ddcuning
Re: A good problem
Post by ddcuning »
You got it Jack.
Dave C
Re: A good problem
Alright, I see it now. The odometer recently stuck on my 82, so I guess that was fresh on my mind.
Andy
Re: Stuck Odometer Repair
I used to have a bunch more pictures of an odometer repair I did on an '81 LUV. Here's a link to another member's repair. viewtopic.php?f=1&t=15403&hilit=odometer
I found a few in my old Photobucket account, and saved them back to my hard drive.
