As most VE info is a scattered mess:
Dis-assembly / assembly instructions for the Bosch Kiki VE
with and without altitude compensator:
Assembly Instructions Bosch Kiki Inline and VE Pumps (70mb Large File)
http://www.4x4.ee/docs/nissan-SD-die...es/sd-3of3.pdf
ENGINE FUEL & EMISSION CONTROL SYSTEM: VE Pump assembly / diss-assembly (15mb)
http://woollett.net.nz/static/4WD/GQ...emanual/EC.PDF
PDF of Bosch VE design and operation:
Bosch VE Manual
http://gershon.ucoz.com/BOSCH/DIESEL...h_VE_Pumps.pdf
An illustrated guide to resealing a Bosch VE pump, EXCELLENT assembly reference:
Rebuilding Bosch VE
http://gnarlodious.com/Vanagon/Bosch_Pump/-Rebuild
BOSCH VE GUIDES -
11mm Hybrid Bosch Pump + Gov Mod: Peugeot 306
http://306oc.co.uk/forum/thread-212.html
Bosch Pump Setup and Tuning: Peugeot 306
http://94.23.248.6/forum/thread-145.html
Governor Shimming: Peugeot 306
http://306oc.co.uk/forum/thread-79.html
Bosch VE Video Guides: Peugeot 306
http://94.23.248.6/forum/thread-2398.html
Maximum Throttle: Peugeot 306
http://306oc.co.uk/forum/thread-1356...ighlight=bosch
Pump change video guide: Peugeot 306
http://306oc.co.uk/forum/thread-2145...ighlight=bosch
Bosch Pump Number Guide: Peugeot 306
http://306oc.co.uk/forum/thread-2942...ighlight=bosch
- LDA Rotating: Peugeot 306
http://youtu.be/6zPnjE3neoM
- Governor Modifications non cradle (no use really): Peugeot 306
http://youtu.be/3wSkV-5ozWA
- Governor Modifications Cradle: Peugeot 306
http://youtu.be/eaC7LhNhNf8
- A cut away diagram of a Bosch VE Governor Cradle in action: Peugeot 306
http://youtu.be/6j0vrfaXPmw
Tdi Injection Pump Tuning Tips: LDA Tips
http://dividingcreekimports.com/TdiI...umpTuning.html
Appropedia:
http://www.appropedia.org/Bosch_VE
Bosch VE Injector Pump Governor Spring Swap: The 1989-1993 Cummins Bosch VE injector pump:
http://dieselconversion.com/knowledg...rformance-Tips
Replacing the Rear Seal on the VE Injector Pump
http://memberfiles.freewebs.com/30/8...tor%20Pump.pdf
Injection pump removal, disassembly, cleaning, reassembly, and installation
http://zaruserv.uta.edu/Jetta/Inject...20cleaning.pdf
AAZ Injection Pump Manual Transmission - DBW LLC
http://www.dbwllc.net/wp-content/upl...ansmission.pdf
BOSCH VE injection pump pressure regulating valve adjustment and repair
http://www.dbwllc.net/wp-content/upl...tor_Repair.pdf
Mechanical Diesel Injection
http://www.disa.it/pdf/03HystoryOfDieselFuelInj.pdf
The American Society of Mechanical Engineers
ROTARY DISTRIBUTOR DIESEL FUEL INJECTION PUMP
http://www.ig-smz.de/sites/TGG/JDEP/historie.pdf
tuning the Injection Pump of Land Rover Tdi Engines
http://www.landroverweb.com/Pdf-file...ines_Rev_2.pdf
Bosch VE IP: Pdf's, manuals, tutorials, stock, performance
- DieselJeep
Unskilled, uneducated, inexperienced, tools/facilities lacking, and faint of heart, be warned:
All vehicles are hunks of crap. Designed by individuals, the majority of which, have never turned a wrench.
Which one do you want to fall in love with?
