Engine decoding question
bosco1961
Isuzu vehicle(s): 1989 Isuzu 2.3 2x4
Postby bosco1961 » Sat Oct 05, 2019 12:16 pm
Hello,
I have a question about the 2.6 4 cylinder and I was wondering if they have a 4zD1 on the side of the block or is it just a 2.3 motor? The motor is out of a 91 Trooper and wondered if it was a 2.3 instead of a 2.6
Re: Engine decoding question
Postby oldestisuzuist » Sat Oct 05, 2019 4:19 pm
2.6 engine designator is 4ZE1, 4ZD1 is a 2.3
'91 Troopers only came with the 2.6 4cyl or 2.8 GM 6cyl engines, both fuel injected. If the engine in question is the stock engine it's a 2.6, if it has "4ZD1" cast into the block it's a 2.3 & not stock to a '91 Trooper.
bosco1961
Postby bosco1961 » Sat Oct 05, 2019 4:34 pm
Yeah maybe somebody put the 2.3 block in there and it does have fuel injection. So is the bore and stroke different on the 2.6 versus the 2.3?
bosco1961
Postby bosco1961 » Sat Oct 05, 2019 4:41 pm
Thank you for responding, is there any way to tell what year the motor is on the Block?
Postby oldestisuzuist » Sat Oct 05, 2019 5:07 pm
bosco1961 wrote:Yeah maybe somebody put the 2.3 block in there and it does have fuel injection. So is the bore and stroke different on the 2.6 versus the 2.3?
Yes.
2.6 also has bigger valves unless the 2.3 is the Impulse version.
Postby JoeIsuzu » Sat Oct 05, 2019 7:16 pm
And there were SOME 2.3 (4ZD1) engines with fuel injection -- from the factory.
bosco1961
Postby bosco1961 » Mon Oct 07, 2019 7:48 am
I think 1990 was the first year of fuel injection on the 2.3 but I could be wrong
Postby JoeIsuzu » Mon Oct 07, 2019 1:17 pm
bosco1961 wrote:I think 1990 was the first year of fuel injection on the 2.3 but I could be wrong
Some years ago, I pulled a transmission from a 2wd Amigo that had a 2.3 with FI. I vaguely remember it as an '89 model, but I can't be 100% sure.
Postby Red Truck » Fri Oct 11, 2019 1:51 pm
bosco1961 wrote:Thank you for responding, is there any way to tell what year the motor is on the Block?
I should've responded earlier, but if it's any help: My door panel 'date of manufacture' is August 1986 (for the '87 model year), and my engine block number is 322687. It's a 4ZD1 2.3 liter, and I'm positive it's orig-o. Maybe this will assist in building a time-line for narrowing down the birthdate of your motor.
