Rim Help
Stevo
Isuzu vehicle(s): 1981 Chevy LUV
Rim Help
Postby Stevo » Sat Jan 26, 2019 3:28 pm
Hello, I have a 1981 Chevy Luv 4x4 Diesel and I am in need of 4 matching rims 14 inch 6 lug, a friend gave me what I think is Mazda and they will not work the bolt pattern is the same but the offset is like 6 inches and I think I need 4 inches, I can't find any new anywhere and used ones are a long ways away and expensive any ideas? Are the 2wd and 4wd rims the same size? Are all the hub holes the same? I found some steel ones a in a junk yard on the other side of the state but they are not the white spoked ones and the guy said they were off of a 2wd. Do the 4wd and 2wd trucks have the same offset? I had no idea finding rims was going to be this hard I should have waited on buying tires. Thanks
Re: Rim Help
Postby JoeIsuzu » Sat Jan 26, 2019 6:54 pm
I'm sure somebody here can answer your questions. Wish I could.
Stevo
Re: Rim Help
Postby Stevo » Sun Jan 27, 2019 2:43 pm
Thanks the 2wd rim lug pattern and hub hole are the same as the 4wd but the backspace or offset not sure of the correct terminology is not the same I may try 1.5 inch wheel spacers if I can't find 4wd rims.
Re: Rim Help
Postby Halden » Sun Jan 27, 2019 9:30 pm
The 4x4 and 2wd off set are a little bit different. I can't remember the exact amount. I believe the 4wd rims are set a little bit differently. I can't think if it is more positive or negative. The FSM shows 2wd as 5j-14 and 4wd as 51/2JJ-14....
Re: Rim Help
Postby puttputtinpup » Fri Feb 15, 2019 12:09 am
I've seen some trooper rims on 4x4 pups. They're 15" i think but will probably clear things okay.
mojogoat
Isuzu vehicle(s): 82 luv diesel SB 2wd
Re: Rim Help
Postby mojogoat » Sun Feb 17, 2019 8:22 pm
Caught these on amazon for $61 each, no tax free shipping. Couldn't find used ones that cheap. 6 hole 5.5"
Just keep searching on amazon and you may find deals like this.
https://www.amazon.com/gp/product/B00SY ... =UTF8&th=1
