Center console
minidiesel
Center console
Postby minidiesel » Fri Nov 09, 2018 8:44 pm
I finally found a factory center console, with arm rest.
Now comes the wiring part. It's from an 86 gas going into 86 diesel. 6 wires, black,yellow(w/blue tracer),green(w/red),yellow,red(w/green),and green(w/white). Anybody no the destinations? Do i need different sending units?
1986 Isuzu pup long bed diesel 5 spd 2 wd .
1986 winnbago lesharo Renault turbo diesel.
minidiesel
Re: Center console
Postby minidiesel » Sat Nov 10, 2018 7:04 pm
I found the wiring diagrams. Gas and diesel are the same color code wire. Could i be so lucky as to have that connector(plug in 6 wire) already in my wiring harness?
Re: Center console
Postby puttputtinpup » Sat Nov 10, 2018 7:32 pm
Does your truck already have the oil pressure gauge sensor (rather large & round) or only the pressure switch for the dummy light?
minidiesel
Re: Center console
Postby minidiesel » Sat Nov 10, 2018 7:47 pm
I feel like i hit the lotto, finding the console w/armrest, and i just found the plug in under the dash in my harness. Hooray . I'm not sure where is the gauge sensor located if it there.
minidiesel
Re: Center console
Postby minidiesel » Sat Nov 10, 2018 7:49 pm
I would guess i just have a pressure switch since i am only equipped with a dummy light.
Re: Center console
Postby puttputtinpup » Sat Nov 10, 2018 8:36 pm
Trucks with the console & gauge usualky have a T with the dash light sensor and the sensor for the gauge. Right side of engine. Low.
minidiesel
Re: Center console
Postby minidiesel » Sat Nov 10, 2018 9:23 pm
Thanks I'll look in the morning. Is that a universal type sender or isuzu specific?
Re: Center console
Postby puttputtinpup » Sun Nov 11, 2018 6:38 pm
minidiesel wrote:Thanks I'll look in the morning. Is that a universal type sender or isuzu specific?
I bought one new from Jerry Lemond many years ago. Look up the sender for a gasser truck and see if advance or rockauto carries one.
Re: Center console
Postby puttputtinpup » Sun Nov 11, 2018 6:43 pm
I found a few listed for an 86 trooper 2.3. https://www.rockauto.com/en/catalog/isu ... witch,4588
minidiesel
Re: Center console
Postby minidiesel » Thu Nov 15, 2018 6:51 pm
Awesome ,thanks puttputtinpup, I'll check those rockauto part numbers at local napa and see if i can have an oil pressure gauge reading this weekend. I much prefer a number to an idiot light.
minidiesel
Re: Center console
Postby minidiesel » Tue Dec 25, 2018 5:51 pm
Console is in and working( still waiting on delivery of my oil pressure sender). Had to splice, soldering wires to extend 3" to reach plug in. Installed green led backlights. Got a price off $100.oo to make a new shift boot( not the rubber sealing one on the floorboard) the leather one up top, that sounded high. Cut the old one apart and stitched a new one myself for $6.oo (took 1 1/2 hour ). The $100.oo probably wasn't out of line.
Re: Center console
Postby puttputtinpup » Tue Dec 25, 2018 6:13 pm
Looks pretty good!
minidiesel
Re: Center console
Postby minidiesel » Tue Dec 25, 2018 6:39 pm
Before, and after and led lit. Thanks
Re: Center console
Postby JoeIsuzu » Tue Dec 25, 2018 7:25 pm
That looks GREAT. Did you use leather, or vinyl?
minidiesel
Re: Center console
Postby minidiesel » Tue Dec 25, 2018 8:08 pm
Thanks, I used a marine rated vinyl, hoping it would take the heat and last a good while.
