Oil leak help
IdaPup
Isuzu vehicle(s): 1986 Pup 4X4 5spd 2.3L
Oil leak help
Postby IdaPup » Thu Nov 08, 2018 2:18 pm
I think I've isolated the oil leak to the oil filter housing. Only leaks when running. This housing thing is a separate manifold-like object that exists solely to screw the oil filter onto. I think oil is leaking from between the engine and housing. Internet searches aren't showing me a gasket/o-ring for my year model. Can anyone shed some light on this? Thanks.
86 Pup 4X4 2.3L 5spd
Re: Oil leak help
Postby JoeIsuzu » Thu Nov 08, 2018 4:20 pm
I'm not at all familiar with the 2.3, but there's definitely a seal on the C223 diesels. I suspct the 2.3 has them, although they may not be the same. I'd email Jerry ("JLEMOND" on this site) -- jlemond@bellsouth.net and he probably has them.
IdaPup
Re: Oil leak help
Postby IdaPup » Fri Nov 09, 2018 1:30 am
Thanks for the reply. So is Jerry a source for lots of parts?
I went to take that housing off to see what the gasket looked like and discovered all the bolts holding it to the block were loose. After tightening them the oil leak is much slower now. I may continue looking for the slower leak source but at least it's manageable now.
Re: Oil leak help
Postby JoeIsuzu » Fri Nov 09, 2018 5:56 am
Jerry is THE source for any genuine Isuzu parts that are still available, and he probably has some parts that are unavailable elsewhere. That's not saying he can get absolutely everything. Unfortunately, there are some parts that are just no longer available anywhere except via the salvage market and the occasional eBay seller who decides to unload some old stock parts.
Re: Oil leak help
Postby Halden » Fri Nov 09, 2018 7:08 am
For me I just use a nice thin layer of "the right stuff". Works great every time. Even had to hold an oil drain plug in place with it on my 64 c20 because the threads were stripped out. Just don't put gobs of the stuff on. A nice thin bead is all you need.
IMHO it's a little better than a gasket for certain applications like this because these engines weep oil from vibration and that stuff conforms to every tiny irregularity.
Re: Oil leak help
Postby Red Truck » Fri Nov 09, 2018 3:22 pm
Maybe you haven't discovered it yet, and it took me a while, but there's a factory OEM parts source on this very wonderful website. It's proved invaluable to me many times over. It's under Parts, Sources for Parts, Need a Factory Part Number?, click on the first akadia.ru link, and choose your rig. Don't be alarmed that some of it is in Cyrillic. Your gasket appears to be OEM part #8942236820, according to the diagram.
IdaPup
Re: Oil leak help
Postby IdaPup » Tue Nov 13, 2018 4:24 pm
Thanks I'll keep that part number. For now I'm going to leave it be because it appears to have sealed up.
