E-Stop Kill Switch
JMBoyle
E-Stop Kill Switch
Postby JMBoyle » Fri Oct 12, 2018 3:07 pm
Hey, I have an '84 S-10 Diesel I want to use a log splitter. I'd like to hook up an emergency kill device, but I'm not sure how to do it. The splitter came with a kit, but it is for gas powered engines. does anyone know if there's a wire I can cut that will stop the engine?
Thanks.
'84 Chevy S-10, 5 Spd, 2WD, 2.2L diesel, reg cab.
sanramonrover
Isuzu vehicle(s): 1991 KB (AKA TFS) 4X4 with 4JB1 Diesel
Re: E-Stop Kill Switch
Postby sanramonrover » Fri Oct 12, 2018 4:16 pm
The 4JB-1 diesel in my pickup has a theft-deterrent switch that hooks into a fuel cutoff solenoid on the diesel injector pump. Works perfectly to stop the engine.
Perhaps you injector pump has similar?
1991 KB 4X4
1988 VW Westfalia
1975 Triumph Spitfire
downunderyank
Isuzu vehicle(s): spacecab diesel Holden rodeo 1993, 1986 pup spacecab, 1987 pup spacecab
Contact:
Postby downunderyank » Wed Oct 17, 2018 7:44 am
Firstly, as said, the fuel shut off solenoid on the back of the injection pump is the only thing electrical that will shut your diesel off. Secondly, if you still have the transmission that was on your s10 with a c223 diesel, I'd like to buy it :-)
converted '86 diesel spacecab
