I have more questions
lucas
Isuzu vehicle(s): 2002 Trooper TOD/4WD 1991 Space cab LS 4wd
Postby lucas » Thu Sep 06, 2018 11:28 pm
After doing a pretty decent tune up on my 2.6 space cab I still have some erratic idle issues.
The list of parts I replaces are as follows
1.Plugs
2. Plug wires
3.Cap and rotor/ sprayed a ton of cleaner into the distributor to wash out the oil
4. new valve cover gasket
5. Air filter
6. Radiator cap/ coolant temp sensor.
7. new walker muffler (old exhaust had more holes then swiss cheese
I have a new fuel filter that I can't seem to find out where it goes yet but I haven't investigated enough to find it.
So before the new muffler I was having an erratic idle issue when pushing in the clutch would idle from 500 to 1500 over and over sometimes it would stop sometimes id tap the throttle and it would even out. Ive associated the erratic idle to two possible issues, the IACV, or the TPS.. I still don't know enough about these trucks to make an educated guess. Having owned 5 other vehicles from the early 90's I know they all have IACV problems in one way or another. I also have noticed after driving it the last few days after the idle stabilizes it will sometimes begin to creep up slowly another light tap would correct this also.
Although I noticed this evening that after I installed the new muffler the truck had the opposite problem, started fine and idled normally around 900rpms after running for a few mins either my RPM gauge stopped working or it was idling lower then 500rpm or below. I also noticed a slight miss, either the distributor is still goo'd up or I still have aforementioned problems.
While changing the coolant temp sensor I saw near the bottom of the engine there was a sensor with two wires come off of it that weren't connected to anything. I have consulted my factory manual and haven't found what its for yet, but I doubt its related to my idle problems.
If anyone can shed some insight on my idle problems id greatly appreciate it, there are a few vacuum concerns and while I had the valve cover off I completely forgot to check the head bolts but did wiggle the valves and non were loose.
Re: I have more questions
Postby Red Truck » Mon Sep 10, 2018 3:24 pm
I don't have your engine type, but maybe I can offer a hand: All I see are two plug/pin connectors coming out of a cable-wire bundle. Partially hidden under the cable bundle appears to be the oil pressure sender. Mine has a single wire, tho later models have two wires. Does your oil pressure light work? Otherwise, 'what is this sensor with two wires of which you speak?' Can you tell what colors are the wires?
I had to look up what an IACV was, and from the description of what happens when they go bad, it appears to fit your symptoms perfectly. Kinda sucks they're about $200 a pop, maybe they come apart somehow......
'87 Isuzu p'up 2.3 gas, 5spd, 4WD, base model, Fed spec
Clam
Isuzu vehicle(s): 1988 Isuzu Spacecab 2.6 L Gas.
Postby Clam » Sat Feb 15, 2020 1:26 am
Part of my idle problem is no mechanics nor I do timing light adjustments. I emailed Jerry Lemond and he recommended Kurt in Spartanburg South Carolina. Kurt used a timing light on my 2.6L gas spacecab and most of the idle problems went away including a misfire that developed after changing the timing belt. Jerry trained Kurt.
https://www.google.com/search?q=certifi ... ir%2520Inc
gruff54
Postby gruff54 » Sat Feb 15, 2020 5:48 am
per Jerry, about 10 yrs ago:
SOUNDS LIKE YOU MAY HAVE A BAD IDEL AIR CONTROL VLV, GIVE THIS A TRY, OVER ON THE BACK SIDE OF THE ENG YOU WILL SEE TWO LARGE BLACK HOSES LOOKS LIKE HEATER HOSES ONE GOES INTO THE AIR IN TAKE PIPE AND THE OTHER PLUGS ON TO THE THROTTLE BODY, TAKE EITHER ONE OFF AND SPAY A GOOD BIT OF PB BLASTER DOWN IN THE HOSE , PREFER BOTH HOSES SINCE ONE HAS A TRAP IN THE BOTTOM, SPRAY BOTH PRETTY GOOD AND LET THEM SIT OVER NITE, NOW WHEN YOU TRY AND START IT , IT WILL SMOKE LIKE A FREIGHT TRAIN BUT SHOULD GO TO FAST IDEL, WITHIN A COUPLE OF SECONDS , IF IT GOES UP IN IDEL SPEED LIKE IT SHOULD IT SHOULD THEN RUNAT ABOUT 1200 RPM OR SO AND THEN START SLOWING DOWN TO A NORMAL IDEL, IT SOUNDS LIKE THE SHUTTER DOOR IS STUCK, JERRY
Mike
'89 Trooper 2.6L-5 spd
'87 Trooper 2.6gas to 4jb1-t swap(in progress)
