Fix solid axle issues and motor swap
I'm luving it
Re: Fix solid axle issues and motor swap
Postby I'm luving it » Tue Sep 11, 2018 1:09 am
Slowly getting stuff done. It’s been a challenging having to make one off stuff and getting things to work. Currently working on getting driveshaft made. The conversion from small Isuzu u-joints to bigger Toyota joints caused some slow down. I also got rid of the carrier bearing to install a one piece drive shaft. To keep it low as low as possible I am doing a spring under step up. 5.29 gears have been installed and now I am waiting on flat cross over steering arms. Transmission is in and motor is ready to go. Power steering is all set up and ready to go. Under hood is pretty much done. Torn out dash and heater items to dynomat and add some 3/4 foam to quite it down in the cab. Still have set pinion angles and get front axle put back together. Slowly but surely.
1982, Diesel, reguler cab, short bed, 5 speed, 2wd, 185/75/14, 2" exhaust, tiny tac, 35-40 mpg.
I'm luving it
Postby I'm luving it » Sun Oct 28, 2018 5:53 pm
Wow this is a slow project. Been waiting on custom parts.
-Rear driveshaft completed and installed. Used a yoke from a Chevy to accommodate larger ujoints. Cut out carrier bearing and installed one piece driveshaft.
-Currently having a heater core reworked for the truck. Got rid of the plastic heater core for an all metal one from an 81.
-Currently working on swapping crankcase/oil pan for a Turbo 4x4 one so it clears the front diff and for a turbo later on.
-Still waiting on custom flat steering arms to be made. Open 5.29 gears installed in front. Still have to rebuild axle with vented rotors and ungraded locking hubs.
-Dash and steering wheel has been switched out. The firewall has been completely sound proofed and 3/4 foam added. High idle override has been installed and a mini tach wired.
-Large Power steering cooler was installed.
-Rear axle completely rebuild with 5.29 gears and a spool.
-Fuel filter relocated to beside fuel tank.
Pictures to follow.
soot fart
Postby soot fart » Wed Oct 31, 2018 4:47 pm
Looks good. Very nice pictures.
I'm luving it
Postby I'm luving it » Thu Nov 08, 2018 7:58 am
Shiny oil pump is new turbo oil pump.
2wd pan is whiched to a turbo 4x4 Pan for clearance of front differential.
I'm luving it
Postby I'm luving it » Mon Nov 19, 2018 12:50 pm
Little more work done this weekend. Just trying to figure out how I want it all to fit together. Turbo is a GT1548.
