turbo pup glow plug wiring and intake????
Pupfocused
Postby Pupfocused » Sun Jun 02, 2013 6:59 pm
I just got a turbo space cab with a n/a motor. The motor was changed and I have a turbo motor which I may install. The droping resistor is mounted on the fender and the glow plug relays (unmounted now) appear to have been mounted closer to the fire wall than the other pups that I have seen. If the glow plug wiring is different on a turbo pup would someone with one post a picture. I also have a lot air intake parts not mounted on the truck and would to see a picture of the air intake assembly.
Thanks
Jim
1981 diesel pup
1985 4x4 diesel pup
1986 diesel trooper
