C223T FUEL INJECTION PUMP LEAKING
gendoc
Re: C223T FUEL INJECTION PUMP LEAKING
Postby gendoc » Sat Jan 24, 2009 4:53 am
southeast diesel service in chat tn.
SCpup
Postby SCpup » Sat Jan 24, 2009 9:23 am
ZEXEL(DIESEL KIKI) is 146600-2120 this is a part number for the kit that works for the csd.... this is a numlber for a company in charleston sc but they are very helpful 843-553-8331. you might give them a call, and ask for a local dealer... i actually called someone out in washington state, and he gave me a local number. the kit is the one that works, and the only thing is to access to the csd. but it can be reached through the passengerside wheel well. becareful, because the screws can drop out never to be seen again.
84 pup every day driver
05 toyota tacoma on 33"
Corey
Postby JoeIsuzu » Sat Jan 24, 2009 9:37 am
If removing the CSD, always remove the fuel return line first. Some have reported breaking this line if left connected.
Gerald K4NHN
Postby Gerald K4NHN » Sun Jan 25, 2009 12:47 pm
Corey
I finally got my PuP home. If you're in town give me a call and see if I'm home and stop by. Now to try and get it cleaned up. I need a little warmer weather to get in the water.
Gerald K4NHN
Cayce, SC
Gerald K4NHN
Cayce, SC
"One test is worth a thousand opinions"
1983 LS DIESEL LONG BED 2 W/D 126K miles
1986 LS Trooper Tubro Diesel 4 W/D 186K + miles SOLD
SCpup
Postby SCpup » Sun Jan 25, 2009 5:26 pm
hey im in alabama for another week. but soon as i get back ill come see you
Corey
Gerald K4NHN
Postby Gerald K4NHN » Sun Jan 25, 2009 6:51 pm
Have a nice safe trip, see you when you get back.
Gerald K4NHN
Cayce, SC
Gerald K4NHN
Cayce, SC
wvofedpup
Postby wvofedpup » Mon Jan 26, 2009 12:22 pm
I had mine rebuilt at a local shop here in Austin, Triplet diesel injection, and it cost me 430. 375k on the clock when it was done and the guy said it looked brand new inside. 416k on it now and not an issue yet, running 25k of that on wvo. I can confirm that these are easy to get parts for. While they are not exactly the same, bosch used these pumps in rabbits(bosch ve), and from what my shop told me , as long as you have a part number , you can get any seal out there. The injection pump is probably the one thing we will be able to get rebuilt long after other parts get scarce.
85 diesel pup. 413k miles.
