bio diesel, heating water with wood stove heat
trooper T/diesel
Postby trooper T/diesel » Tue Oct 29, 2013 7:52 pm
as stated im looking at doing a bio room, ie added area on to the wood shed.
and using a electric or LPG hot water tank with a circulator set up with a heat exchanger on the stove. to boost the heating capacity of the water tank...
sorta like how are fire place has a water board in the back of it, to help boost the water temp for the oil furnace.
i figure having the stove in the same room as the fumes from the chemicals methanol and lye, :shock: :shock: would be a rather not so wise idea..... :!: :!:
so im trying to figure how far? like on the other side of a wall or 10/15/20 feet away? the farther i go the more heat ill loose, but at the same time i know the fumes from the chemicals are ((VERY)) flammable....
or i could locate the stove at one end and the reactor at the other end of the room that would make for something like 15 feet of space, as well as i plan on having at least 2 doors or more the ventilate when the chemicals are being used.
there is a 110V line in the ground but i figure its an old line and it has not ran in years.
after getting sticker shock at the store, im on the CL hunt for about 250/300 feet of 220V 10-2 line so i can run a hot water tank or a air compressor should i need it.
i haven't made my mind up on the LPG or electric tank yet. i just dont want to have to dig a 2nd dich... :roll:
hearsthe
weather forecast for NW OR
gearbox
Re: bio diesel, heating water with wood stove heat
Postby gearbox » Wed Oct 30, 2013 3:40 pm
I will keep a look out to the west and if I can see a big flash from MN then you were to close . best of luck with it keep us posted David .
Gearbox
81 sport 4x4 diesel [parts]
81 micado 4x4diesel
97 ford 250 7.3 4x4
9600 ford [135 hp tractor]
84 MPG rust over rust 2x4 [parts]
91 space cab soon to be married to above MPG
phil cottingham
Isuzu vehicle(s): 85 s10 with 2.2 diesel
Postby phil cottingham » Wed Oct 30, 2013 7:39 pm
David, If you know anyone that works for the local power company you might pick up some used wire that they have taken down somewhere. That's what I run my shop with about 200ft. from my house. Also keep an eye out for a building being torn down. They can have lots of useable wire. Phil
science
Postby science » Mon Nov 04, 2013 1:36 pm
i don't see any problem with this as long as you use a wood stove, which you should because it's the most efficient method. Lye isn't explosive, it's just a strong base. Methanol is, but you knew that. Btw, more biodiesel producers aree using other catalysts with better production rates. I don't remember any but that's good cuz there was probably some non-disclousure statement involved. I always wanted to use a heat exchanger stuck in compost with a false bottom, but alas, i still have no acerage.
1981 Chevy Luv 2.2L Diesel -- on grease
1982 Isuzu P'up 2.2L Diesel
jerryfreak
Postby jerryfreak » Fri Nov 08, 2013 8:57 am
in our biodiesel plant out biodiesel fired boiler is 50 feet and a firewall away from an engineered room with active methanol moniotoring. i would not locate a combustion appliance in the same area as methanol. it is heavier than air and can form flammable concentration around the entire floor of a room. use hydronics and insulate the pipe and you will have little to no loss even at long distances. any other bd questions hit me up.
trooper T/diesel
Postby trooper T/diesel » Fri Nov 22, 2013 3:54 am
WoW priced some wire just some run of the mill 10/2 stuff....... :shock: :shock: $200ish :shock: :shock:
my word, its IN-SANE expensive :!: :!:
no wonder copper theft is so bad... :(
just one more thing to hunt for on CL each night :lol: :lol: :lol:
its about 200' i figure best to run 220V and then split it at a box. lighting, pumps, drum heaters will add up to around 3,000W worst case.
then....
any one know if electric water tanks run the two elements at the same time or one at a time :?:
two 4,500W elements running makes for a rather massive power load. :!:
i could swap to one of the smaller sizes 3700 2750 or 110V 1500W
going with LPG or wood heat will drastically cut the power load..cuse 200' and a near 9,000w load is abit much for 10/2 let alone the other stuff. was thinking a 30A main breaker as 10/2 is rated for 30A
sadly, i think 8 AWG would be code with a 5% loss not 10 AWG :(
am i over thinking this, is 8AWG over kill??? is 10/2 OK?? for this sorta load?
or do i need to take a loan out, and get bigger wire then 8?
P.S.
im thinking copper wire in all this..
hearsthe
FlukeGE
Postby FlukeGE » Fri Nov 22, 2013 1:57 pm
The elements are supposed to run one at a time.
Ryan
1986 Trooper Gen III
1999 with 4JG2 Coversion
