Return line question with 2 tank svo system
redline808
Postby redline808 » Thu Jul 25, 2013 8:11 pm
I've searched, but did not find an answer.
I noticed the return line from #4 injector goes back to a banjo fitting on the IP. from there it spiders off and one goes back to the tank. the line that goes back to the tank looks to be smaller then the feed line? about 1/4 inch? is that normal?
my question is, do I just take that small line and re-route it to my 3 way return valve?
this is not my first 2 tank system, though it is the first time I have seen a c223 IP.
thank you.
Tigman
Re: Return line question with 2 tank svo system
Postby Tigman » Fri Jul 26, 2013 8:06 am
check your pm's, message sent.
