Questions regarding a propane conversion.
Posted: Sun Nov 18, 2012 6:00 pm
Hey guys, my first time posting in this neck of the woods/forum.
And as you can tell, I have been doing a little bit of homework on propane conversion.
I currently work at a shell station, which has a pump to fill up propane vehicles and cylinders. Filling up all these converted trucks has started to make me consider going about a conversion.
What I find appealing the most is that fact that the propane gas is half the price of normal gasoline today:
66 cents Canadian per litre / 2 dollars 50 cents Canadian per gallon for propane
V.S.
1 dollar and ~20 cents Canadian per litre / 4 dollars ~ 50 cents a gallon (Canadian gas prices... sigh
Not to mention I can fill up my truck as I please, as I am already fully certified to handle compressed gas.
The conversion that has the most appeal to me would be a dual-fuel setup, giving me the ability to switch between Gasoline and Propane with the flick of a switch.
These setups appear to be quite simple, as the only modification the the engine is a modified carburetor and a fuel cut-off system. I was already preparing for a weber carb swap, so why not go a little bit further?
Other then that, I can just make some mounts for removable 40 lb forklift cylinders, or even a larger 100-150 litre tank if I can get my hands on one.
What I want to know from you guys is if any of you have decided to take this route, and if there are any available kits specifically for an isuzu truck, or even ones that will fit with an adaptor plate.
Thanks in advance guys! Any advice is great advice!
V.S.
