84 Diesel just got home
This is for "Introductions". Tell us about YOUR P'up, and a little about yourself (if you like). This is also the place for updates, tall tales, etc. about YOUR P'up. No technical questions here, please.
Forum rules
This forum is to be Family Friendly.
This is for "Introductions". Tell us about YOUR P'up, and a little about yourself (if you like). This is also the place for updates, tall tales, etc. about YOUR P'up. Include photos of your truck, if available (See this for an example).
This is not the appropriate place for technical questions. Please post those in the appropriate Troubleshooting or Upgrades section.
NOLAPup
Isuzu vehicle(s): 1984 Isuzu Pup Diesel
Postby NOLAPup » Tue May 23, 2017 10:30 pm
Just picked up a 1984 Diesel Pup. My wife's grandfather bought this truck new. It's been at her uncle's house for the past 7 years or so. He hasn't driven it much the past couple of years but made a habit if running it every couple of weeks. I hope to make it my daily driver. It runs good, the clutch is tight, and the power steering seems to be in good shape. Starting next week I'm getting new tires, doing a full brake inspection/job, and performing all typical maintenance. It needs a lot of cosmetic work but that's nothing we're afraid of. I could use some help with covering, refurbing or replacing the bench seat. Any recommendations would be appreciated! I will post a pic of the truck.
NOLAPup 1984 Diesel Long Bed
Re: 84 Diesel just got home
Postby puttputtinpup » Wed May 24, 2017 5:40 am
She's a beauty! Welcome to the site. Since you mentioned the brakes, take a look at my brake bleeder tool review in the tool review section. If you decide to bleed the system the old fashioned way by pumping the brake pedal, then opening the bleeder, etc....be sure the engine is running so there's vacuum to the brake booster.
NOLAPup
Postby NOLAPup » Wed May 24, 2017 6:42 am
Thanks for the info the brakes!
Postby JoeIsuzu » Wed May 24, 2017 9:26 am
Welcome to the site. I love to see P'ups that are kept in the family of the original owner. :)
Postby Halden » Thu May 25, 2017 9:55 pm
You can do a gravity bleed just make sure to put a little bit of plastic line at the bleeder screw to keep it under the fluid.... It just takes a looong time...
Great looking truck!
luvcamas
Postby luvcamas » Thu May 25, 2017 10:41 pm
very nice. remember to use motor oil in tranny if its a manual that is.
1981 2wd diesel LB
1981 4wd diesel SB
1982 diesel 4x4 SB
:mrgreen:
NOLAPup
Postby NOLAPup » Mon May 29, 2017 1:25 pm
Thanks for the info! It is a manual.
Postby puttputtinpup » Mon May 29, 2017 4:50 pm
This engine is an interference engine with a timing belt. This means, if it breaks you'll mess up some push rods and/or rockers. Change the timing belt, or at least take the top cover off and check to see if it's dried out and cracked..any pieces missing. If so, change it out. jlemond (Jerry lemond) will have new factory belts if you send him a PM private msg.
NOLAPup
Postby NOLAPup » Tue May 30, 2017 10:52 am
Thanks for the info on the timing belt!
Postby JoeIsuzu » Tue May 30, 2017 12:59 pm
NOLAPup wrote:Thanks for the info on the timing belt!
Definitely don't drag your feet on replacing that belt. And equally important (but much easier), there's an oil line that goes from the block to the vacuum pump (on the back of the alternator). It's probably way overdue for replacing. It can break inside without any visible sign that it's in bad shape. If it does, you can lose all the engine oil in a hurry. Get one from JLEMOND. And the return line to the pan is just as important (but I don't think they're quite as trouble-prone as the supply line).
