Mystery wires from the glow plug harness
Lilsthomebum
Isuzu vehicle(s): 1982 pup diesel 4x4 with a little luv on the side (doors and tailgate)
Postby Lilsthomebum » Fri Mar 10, 2017 1:25 pm
Controller went out and a manuel system in for a while, which worked great aside from an issue ill get into later-but im putting the factory set up back in from my parts luv. I have everything set and ready to go aside from the 5v plugs coming in the mail but theres a few wires i cant figure out if anyone has any insights. Cant seem to find their source even from the parts truck. The new set uo is off a 81 luv and is going in my 82 4x4 dlx. Its the three wires shown below. One is a green wire with a female connection one is black with a male and one is yellow with a blue stripe with a female. The yellow and black are spliced to the first relay and main connection and im not sure where the green comes from, as i am to cut all the wires free from the tape.
Thanks
Maxwell
Re: Mystery wires from the glow plug harness
Postby Paul » Fri Mar 10, 2017 11:53 pm
I'm pretty sure the yellow/blue & the black wires are the connections for the water sensor at the bottom of the fuel filter. And the green wire is probably the connection for the air conditioner clutch.
I found these wires on my '84 wiring diagram.
Lilsthomebum
Postby Lilsthomebum » Tue Mar 14, 2017 11:22 am
Thanks so much i just recently lost my factory service manuel. Ran into a buddy with a pup here in port townend and double checked and seems like youre spot on.
Postby puttputtinpup » Tue Mar 14, 2017 2:16 pm
Trust me, Paul is ALWAYS spot on! :D
Postby Halden » Thu Mar 16, 2017 9:18 am
puttputtinpup wrote:Trust me, Paul is ALWAYS spot on! :D
He's right about 107% of the time.
83 LS Long Bed Diesel
Postby Paul » Thu Mar 16, 2017 4:29 pm
I like it! But, there may be a bit of exaggeration here :) Thanks though.
