Instrument panel lights with braking
mskreis
Isuzu vehicle(s): 1988 2.3 L
Postby mskreis » Mon Nov 21, 2016 11:22 am
I admit I haven't been driving my truck much in the past several years. I've noticed that whenever I brake, the instrument panel lights. Is this normal? If not, what should I be looking at to resolve this?
Thanks,
Mark
zenapup
Isuzu vehicle(s): 1987 Normal Cab Short Bed 1.9L FED RWD 4-speed manual
Re: Instrument panel lights with braking
Postby zenapup » Tue Nov 22, 2016 1:31 pm
low brake fluid
1987 Isuzu P'UP Normal Cab Short Bed 1.9L FED RWD 4-speed manual
1988 Honda Accord LX-i Coupe 2.0L FI 5-speed manual
1995 Suzuki Sidekick JX 4DR 1.6L 5-speed manual
2005 VW Jetta TDI 1.9L Diesel 5-speed manual
2013 Mazda3 iSV 2.0L 5-speed manual
Postby puttputtinpup » Tue Nov 22, 2016 3:09 pm
Ok, is the brake light on the panel coming in with brake pedal pressed, or ALL dash lights coming on?
gearbox
Postby gearbox » Tue Nov 22, 2016 4:37 pm
Brake light grounding through tail light . Look for 1 brake light dimmer than the other . Fix the ground on that one .
81 sport 4x4 diesel [parts]
81 micado 4x4diesel
97 ford 250 7.3 4x4
9600 ford [135 hp tractor]
84 MPG rust over rust 2x4 [parts]
91 space cab soon to be married to above MPG
mskreis
Postby mskreis » Tue Nov 22, 2016 6:08 pm
puttputtinpup wrote:Ok, is the brake light on the panel coming in with brake pedal pressed, or ALL dash lights coming on?
Yes, all dash lights are coming on.
mskreis
Postby mskreis » Tue Nov 22, 2016 6:11 pm
gearbox wrote:Brake light grounding through tail light . Look for 1 brake light dimmer than the other . Fix the ground on that one .
I'll check. Am I looking for a broken wire,connection within the tail light assembly?
gearbox
Postby gearbox » Wed Nov 23, 2016 8:04 am
Could be or a bad contact on the bulb . I have seen a filament broken in the bulb drop down and touch the other . I would say it is grounded through the harness . start by wiggle the bulbs . or buy a new one and change and try method .
81 micado 4x4diesel
97 ford 250 7.3 4x4
Postby puttputtinpup » Wed Nov 23, 2016 3:13 pm
gearbox wrote:Could be or a bad contact on the bulb . I have seen a filament broken in the bulb drop down and touch the other . I would say it is grounded through the harness . start by wiggle the bulbs . or buy a new one and change and try method .
That's kinda what I was thinking. A filament on one of the bulbs is crossed over onto another filament and ground is backtracking through the parking/dash light circuit and partially grounding that way. One of the tail light bulbs will likely be the culprit
mskreis
Postby mskreis » Thu Nov 24, 2016 5:42 pm
Wow, the bulb was the culprit! I would have never considered that since it was working fine. Thanks for the help.
Mark
Postby puttputtinpup » Thu Nov 24, 2016 6:10 pm
How I feel when I fix something - Copy.jpg (70.28 KiB) Viewed 8426 times
:lol: :lol:
