led headlights
minidiesel
led headlights
Postby minidiesel » Wed May 06, 2015 12:40 pm
Did you get those jack? Anybody else retro fit to led headlight kit yet? I think I have a big enough alternator if I get rid of those power hungry halogens.
1986 Isuzu pup long bed diesel 5 spd 2 wd .
1986 winnbago lesharo Renault turbo diesel.
Re: led headlights
Postby JoeIsuzu » Wed May 06, 2015 1:21 pm
Not yet.
jeffneal66
Re: led headlights
Postby jeffneal66 » Sun Jul 05, 2015 9:30 am
You should really check out these head lights:
http://www.ebay.com/itm/Truck-Lite-2745 ... 63&vxp=mtr
They are DOT approved and made by a company that established itself with military equipment. Very good stuff.
'82 Chevy Luv 4x4 w/2.2 Diesel
Jeff
jeffneal66
Re: led headlights
Postby jeffneal66 » Sun Jul 05, 2015 9:43 am
Here is the press release from Truck-Lite:
http://www.truck-lite.com/webapp/wcs/st ... &langId=-1
Jeff
dragginmini
Isuzu vehicle(s): 90 Pickup with amigo front body panels,static drop, 2.3 4zd1 5 spd. dana 44 rear diff. plans to bag and lay out in near future
Re: led headlights
Postby dragginmini » Sat Mar 18, 2017 1:12 pm
I have the h4 conversion housings and the x7 led headlight swap it's h4 bulb and they are seriously bright
90 isuzu pickup.2.3l 5speed (carbed) dropped on 16s with 20s back in storage till rebuild. BLOOD BATH
Re: led headlights
Postby JoeIsuzu » Sat Mar 18, 2017 1:23 pm
dragginmini wrote:I have the h4 conversion housings and the x7 led headlight swap it's h4 bulb and they are seriously bright
Are you saying they're halogens, with LEDs around them? Post up some pics.
Personally, I'm hoping there will be some good LED conversions by the time I'm ready. I'm trying to avoid the power drain and heat of halogens, and get the longevity that only comes with LEDs.
dragginmini
Re: led headlights
Postby dragginmini » Sat Mar 18, 2017 1:46 pm
no they are housings that take a h4 bulb. Direct replacement for the halogen bulb and the has a opening for the h4 bulb in the back.
dragginmini
Re: led headlights
Postby dragginmini » Sat Mar 18, 2017 1:49 pm
this is a little better look at them
Re: led headlights
Postby JoeIsuzu » Sat Mar 18, 2017 3:06 pm
So is there a single element for both high and low beam settings?
Can you post a link to what you got?
jamezg
Isuzu vehicle(s): 86 2.3 longbed gasser, 86 2.2 turbo spacecab, 87 NA longbed
Re: led headlights
Postby jamezg » Sat Mar 18, 2017 3:10 pm
i installed these in my rabbit. They say they fit the Isuzu.
They don't work well because they are floodlights and don't' shine very far, and blind oncoming drivers.
They are super white, bright, cheap and only draw 3 amps on high.
https://smile.amazon.com/gp/product/B00 ... UTF8&psc=1
74 610 PU dump truck
77 dodge custom fire van.
80/82 VW caddy Diesel
84 Sabru brat -broken
84 Toyota motorhome converted to flatbed
86 Isuzu P'up TD spacecab
86 Isuzu p'up 2.3L longbed
87 Isuzu P'up NA longbed
Forklift,excavator,tractor,motorcycles
Re: led headlights
Postby JoeIsuzu » Sat Mar 18, 2017 5:59 pm
jamezg wrote:i installed these in my rabbit. They say they fit the Isuzu.
Good info, thanks.
dragginmini
Re: led headlights
Postby dragginmini » Sat Mar 25, 2017 1:13 pm
I have the x7 led headlight system. It's high and low beam just like regular
Re: led headlights
Postby JoeIsuzu » Sat Mar 25, 2017 1:22 pm
dragginmini wrote:I have the x7 led headlight system. It's high and low beam just like regular
I think I understand now. Basically, two separate conversions.
First, An H4 conversion, that replaces sealed beams with a reflector/housing for H4 bulbs...
Second an LED "bulb" that replaces the halogen H4.
Can you post links to the housing and the bulb?
Thanks.
dragginmini
Re: led headlights
Postby dragginmini » Sun Jul 09, 2017 10:24 pm
Exactly
Return to “Electrical Troubleshooting, Maintenance, and Upgrades”
