Alternator wiring woes, help!
DoodooIsuzu
Postby DoodooIsuzu » Thu Feb 07, 2013 5:23 pm
Alright so I'm wiring up the KA24 alternator to the Isuzu Chassis. I have the 240 Dummy light running the to dash already, but there's something stumping me. I know there's an alt. wire that goes to the fusebox for both cars, but on the Isuzu alternator setup there's a thick white wire on the three plug connector and a fatter white wire with its own clip. They both meet up in a fusible link and go to the fusebox. My question is the single clip wire, should that just be merged on the 240 plug, or does that go with the battery terminal connector on the back of the alternator? Here's a picture to help.
As you can see the fat wire on the 240 alternator would go to the 240 fusebox, but I'm splicing the Isuzu wire off the 3 wire connector. It's the back connector from the Isuzu I'm wondering about, does that back wire go to the ALT battery connector, or would I put both to the 240 plug? Thanks in advance.
92 pickup with a KA24DE! Lowest static truck in town. Rodeo goodies all over.
margaret fishman
Re: Alternator wiring woes, help!
Postby margaret fishman » Fri Feb 08, 2013 3:55 pm
GEE :D I HAVE A WIRING MANUAL .I'LL SEE WHAT I CAN FIND FOR U .IT WILL BE LATER TODAY . MARGARET
JOHN 3: 16'88 5-SPD P'UP2.3 '2000 DODGE DAUL ,95 CHEVY V6 5SP[81 DIESEL 5 SP FLAT BED ,92 NISSAN 4X4 5SP ,96 S-10 PK I'VE REACHED THAT AGE WHERE MY BRAIN W/FROM 'I PROBABLY SHOULDN'T SAY THAT ' to OH WHAT THE HECK LET'S SEE WHAT HAPPENS
DoodooIsuzu
Postby DoodooIsuzu » Fri Feb 08, 2013 5:08 pm
Thanks! Just let me know.
DoodooIsuzu
Postby DoodooIsuzu » Fri Feb 08, 2013 5:17 pm
Oh, if you still have the diagram out! I needed to know the Positive and negative for the coil. I think the black/red is negative and black/blue is positive. Can you confirm this?
margaret fishman
Postby margaret fishman » Fri Feb 08, 2013 9:19 pm
NOT SURE BUT THIS IS WHAT IT SHOWS BLK/BLU LINE COMES FROM FUSE #9 AND IS CALLED THE SECONDARY THAT FEEDS INTO COIL FROM TOP,LEFT , IF LAYING ON SIDE . FOLLOWS STR8 THROUGH TO DISTRIBUTOR CAP (COMING OUT OF THE COIL AS A BLK.WIRE ) THE RED/BLK COMES OUT OF COIL RIGHT SIDE .THERE IS ALSO A BLU WIRE FEEDIND INTO THE PRIMARY OUTPUT CONTROL ON THE IGNITER UNIT.THE RIGHT SIDE OF COIL IS CALLED THE PRIMARY . THERE IS ALSO A BLK/YEL WIRE COMING OUT AT SAME PLACE BLK/BLU FEEDS INTO COIL, AND GOES INTO THE IGNITER UNIT FROM THE TOP . I'LL SEE IF PUTPUTIN CAN TELL ME HOW TO GET A PIC. FOR YOU . MARGARET
margaret fishman
Postby margaret fishman » Fri Feb 08, 2013 9:24 pm
PUTTPUTTINPUP WILL U SHOW ME HOW TO GET PIC ? YOUR THE GO TO MAN FOR THAT. :D
margaret fishman
Postby margaret fishman » Fri Feb 08, 2013 9:56 pm
SORRY I CAN'T GET A PIC YOU CAN READ . SO IS PRIMARY POSITIVE? OR NEGATIVE I COULDN'T TELL YOU BUT SOMEONE WILL IF YOU DON'T ALREADY KNOW
margaret fishman
Postby margaret fishman » Sat Feb 09, 2013 3:44 pm
margaret fishman wrote:NOT SURE BUT THIS IS WHAT IT SHOWS BLK/BLU LINE COMES FROM FUSE #9 AND IS CALLED THE SECONDARY THAT FEEDS INTO COIL FROM TOP,LEFT , IF LAYING ON SIDE . FOLLOWS STR8 THROUGH TO DISTRIBUTOR CAP (COMING OUT OF THE COIL AS A BLK.WIRE ) THE RED/BLK COMES OUT OF COIL RIGHT SIDE .THERE IS ALSO A BLU WIRE FEEDIND INTO THE PRIMARY OUTPUT CONTROL ON THE IGNITER UNIT.THE RIGHT SIDE OF COIL IS CALLED THE PRIMARY . THERE IS ALSO A BLK/YEL WIRE COMING OUT AT SAME PLACE BLK/BLU FEEDS INTO COIL, AND GOES INTO THE IGNITER UNIT FROM THE TOP . I'LL SEE IFPUTTPUTTINPUP WILL SHOW ME HOW TO GET A PIC. FOR YOU . MARGARET
Postby puttputtinpup » Sat Feb 09, 2013 9:15 pm
margaret fishman wrote:PUTTPUTTINPUP WILL U SHOW ME HOW TO GET PIC ? YOUR THE GO TO MAN FOR THAT. :D
if you have a smart phone, you can download an app called CamScanner. It uses the camera's phone to take a picture of (let's say) a schematic diagram. Then you can convert it to a PDF (Adobe Acrobat) file, then choose to email it to your own email, then retrieve it, and post it on the forum.
If not, you can take a decent resolution picture of the page w/ a regular digital camera, download it to your computer, then post it.
DoodooIsuzu
Postby DoodooIsuzu » Sun Feb 10, 2013 10:16 pm
Or send a picture in a picture message to your email, and download it to your computer if you don't have a smart phone.
shooter
Postby shooter » Sun Feb 10, 2013 10:33 pm
Black/blue is pos and black/red feeds tach if so equipped.
1989 Isuzu Trooper S/ 4WD / 2.6 Litre 4 Cyl 4ZE1 Converted to Weber 32/36 Carb / 5-speed Manual (MUA5) / Warn Premium Hubs / Fancy Radio / Deluxe Intermittent Combination Wiper Switch
I'd rather laugh with the sinners than cry with the saints.
margaret fishman
Postby margaret fishman » Sun Feb 10, 2013 10:53 pm
WELL I TOLD YA SOMEONE WOULD COME TO THE RESCUE . CAUSE THAT'S WHAT THE DIAGRAM SHOWS . THANKS SHOOTER :D THANK YOU GUYS FOR THE INFORMATION ABOUT POSTING PIC AND NO I DON'T HAVE A SMART PHONE YET I'M STILL DEBATING W/ MYSELF WHETHER I NEED ONE OR NOT .
DoodooIsuzu
Postby DoodooIsuzu » Mon Feb 11, 2013 3:10 pm
Alright cool, cool. One more question, the oil pressure sending unit that goes to the tach, what color is that wire? Just trying to wrap up my swap.
DoodooIsuzu
Postby DoodooIsuzu » Mon Feb 11, 2013 5:25 pm
And the original coolant temp sensor! I set myself up for failure when I pulled my motor and didn't look at all of the wires. ):
margaret fishman
Postby margaret fishman » Fri Feb 15, 2013 3:29 pm
THE WIRE COMING OUT OF UNIT IS BLUE THEN CHANGES INTO YEL/BLUE
