wiring diagram for 82 luv/pup
chriscarpenter0
Postby chriscarpenter0 » Mon Jan 03, 2011 3:00 pm
I looked all over the net for this info and now i got the book so i hope this helps someone else now.
If there is wheels on it i will drive untill they fall off.....
82 Chevy LUV 5-speed diesel 200,000mi and still going.
chriscarpenter0
Re: wiring diagram for 82 luv/pup
Postby chriscarpenter0 » Mon Jan 03, 2011 3:04 pm
my heater blower quit working this week. man am i bummed. no power to the switch.....power to the fuse and to the relay next to it but nothing after. i hope it is just a bad relay.
Postby JoeIsuzu » Mon Jan 03, 2011 3:12 pm
That says 1986. It does not look like the factory manual, but it's easy to read. What is it?
Here's the factory one for the '83 diesel...
Schematic - 1983 Diesel (except California)
chriscarpenter0
Postby chriscarpenter0 » Mon Jan 03, 2011 3:36 pm
chilton. the top is 82 on the top pic the right on the bottom is 82-85
chriscarpenter0
Postby chriscarpenter0 » Mon Jan 03, 2011 3:38 pm
theres more if yall need them. 81-96 years im still learning how to use the darn scaner though. :P
Postby JoeIsuzu » Mon Jan 03, 2011 3:45 pm
chriscarpenter0 wrote:chilton. the top is 82 on the top pic the right on the bottom is 82-85
chriscarpenter0 wrote:theres more if yall need them. 81-96 years im still learning how to use the darn scaner though. :P
I'm not ready to trust Chilton manuals, especially the ones that "cover" multiple years. We've had quite a few complaints about them. Maybe the electrical systems didn't change much over the years.
The 1983 factory manual has one ~11x17 spread just for the Federal spec diesel, and has the same layout for each of the other three variants (Federal gasser, California gasser, California diesel).
chriscarpenter0 wrote:my heater blower quit working this week. man am i bummed. no power to the switch.....power to the fuse and to the relay next to it but nothing after. i hope it is just a bad relay.
The charge relay won't supply power to the fan unless the system is putting out enough power to close the relay. Is it possible your alternator isn't healthy?
chriscarpenter0
Postby chriscarpenter0 » Mon Jan 03, 2011 3:51 pm
ill check the voltage
chriscarpenter0
Postby chriscarpenter0 » Mon Jan 03, 2011 4:37 pm
what is the voltage suposed to be? can i override that so i can have the fan on?
Postby JoeIsuzu » Mon Jan 03, 2011 5:28 pm
Charging voltage is usually somewhere around 13.5v, isn't it? I don't know what it takes to close that relay, but if your system is putting out 13.5v to the relay, it should close and you should have power coming out.
chriscarpenter0
Postby chriscarpenter0 » Mon Jan 03, 2011 6:37 pm
AH ha! voltage reads 14.5 so i checked the charging relay it loos like hell so i replaced it with the relay i just got for next to the fuse box and it clicks when i plug it in the old one didnt. ill have the relay in the morning man i hope this is it, it makes since cause with the new relay in it powers up two termnals in sted of just one next to the fuse box.
chriscarpenter0
Postby chriscarpenter0 » Tue Jan 04, 2011 1:47 pm
that fixed it the culprit was a bad charging relay thanks jack for the help
Postby puttputtinpup » Tue Jan 04, 2011 5:58 pm
how about posting a picture of this charging relay's exact location..would ya? Many members have this problem with the alternator charging but no fan blowing.
Currently P'up-less, but keeping my eyes open for a good deal
Click this link for misc. diesel technical bulletins & other info
chriscarpenter0
Postby chriscarpenter0 » Tue Jan 04, 2011 6:38 pm
here they are.
Postby puttputtinpup » Wed Jan 05, 2011 8:05 am
thanks. I'll save this picture for the future.
chriscarpenter0
Postby chriscarpenter0 » Sat Jan 08, 2011 4:15 pm
well it turns out i was wrong my alt UNDER LOAD ia barley 12v... a rebuilt alt at orilles is 226.00 bucks. to have it rebuilt is 100.00bucks what are my outher options if any?
Return to “Electrical Troubleshooting, Maintenance, and Upgrades”
