c223 header
jasonw86
Re: c223 header
Postby jasonw86 » Tue Dec 29, 2009 12:37 am
I only speak from experience of having headers on gas engines, so take it for the grain of salt it is worth. Are you making this header for a turbo?
1984 diesel LS long bed 4x4
1983 diesel 4x2 long bed
1984 diesel 4x2 short bed MPG Plus
1984 diesel 4x2 automatic longbed
1982 diesel 4x4 LUV mikado shortbed
1986 gas LS 4x4 Trooper II 2 door
1984 turbodiesel 4x2 automatic longbed
edwright
Re: c223 header
Postby edwright » Tue Dec 29, 2009 12:54 pm
average hi range exhaust temps on an NA are 400 to 600 degrees. Add a turbo and you kick it up to around 1000 tops if you have the fuel turned up and boost up around 8 to 10 lbs. Any higher than that, you got too much fuel or you are pulling too much of a load. 1200 you are at the point of a meltdown.
Ed
1986 Trooper Turbo Diesel LS Red
1986 Trooper Turbo Diesel White
1986 Trooper Turbo Diesel LS Blue
"If by "drag machine" you mean a little truck to transport cross dressers then it should work out just fabulous" VeggieNate
turbo pup
Re: c223 header
Postby turbo pup » Tue Dec 29, 2009 6:41 pm
Thanks for the info Ed. I plan on a pyrometer but Ive planned on a lot of things.
Jason, the thought of a turbo header definately has crossed my mind. I looked at my parents today and found a stash of 1.5" stainless tubing about .065 wall. I have (8) 90degree bends and about 12-15 feet of strait tube. This with the .5" flange aught to make a solid header for the little n/a trucks. Ill be in the market for some thicker walled tubing for a turbo header in the future. Maybe 14 or 12 gauge tubing to support the weight of a turbo. But I want this to happen so Im going to make it one step at a time.Lyle.
86 Isuzupup4x4,5spd,turbo,space cab,AC,p/strng,sun roof
87spacecab2.3gas4x2automatic
85spacecab4x45spd2.3gas
81 chevyLUV2.25spd.4x2no a/c just youre basic shortbed
81chevyLUVdsl
81 Isuzu1.8,5spd fromchevette putin S10. MICE...pulled eng. +goodys junkedS10
downunderyank
Isuzu vehicle(s): spacecab diesel Holden rodeo 1993, 1986 pup spacecab, 1987 pup spacecab
Contact:
Re: c223 header
Postby downunderyank » Fri Apr 16, 2010 6:34 am
Found a set of headers over here in Australia if anyone is interested.
http://cgi.ebay.com.au/HOLDEN-JACKAROO- ... _500wt_975
converted '86 diesel spacecab
Re: c223 header
Postby puttputtinpup » Fri Apr 16, 2010 6:07 pm
I'll bet shipping would be 4x that. nice find. I wish they we a little closer to me. I'd buy them
Isuesyu
Re: c223 header
Postby Isuesyu » Fri Apr 16, 2010 11:38 pm
i might be interested in a stainless steel header. how much? nc 28025
VEGGIE NATE
Re: c223 header
Postby VEGGIE NATE » Sat Apr 17, 2010 11:23 am
I contacted the seller of those headers and was quoted $90 AUD for shipping, would love to have them! nate
1986 P'UP LWB,2WD,N/A,5-SPEED,3.42,WVO TWO-TANK
PUPdiesel
Isuzu vehicle(s): 1986 Isuzu Trooper II diesel
Re: c223 header
Postby PUPdiesel » Sun Apr 25, 2010 12:00 pm
I'm still interested in a turbo header/manifold to turbocharge my Isuzu Trooper diesel as it can't get out of its own way. It is seriously the slowest vehicle I've even driven, but I still enjoy it because of how you sit in it with the vision you have and love shifting the gears. Just would need a manifold with a T3 flange I guess because most all of your smaller turbos mount to that style flange. You can buy them on Ebay, but I believe it's steel and I'm not sure how well you'd be able to weld it to a cast iron manifold to where it would be strong and durable (so it doesn't crack or break at weld joint). Then just use a newer style Garrett turbo like alreadly suggested and be conservative on boost pressure and I think you'd be alright.
265/75/R15 tires
Centerforce dual-friction clutch
w/ 81 C223, needs a turbo!
