2.5 inch exhaust review for c223t
sourgrout
Postby sourgrout » Sat Aug 30, 2008 9:53 pm
So I finally got my exhaust done, original muffler was clogged up with soot pretty bad. when i got it out I could tap it on the ground and about a tablespoon of soot would dump out each time. So I got 2.5" from the down pipe right above the first turn into a 3" in and out flowmaster and 2.5 tail pipe. This is in my turbo trooper and wow what a difference. My original mileage stock was right at 25mpg per tank give or take a half a mpg, running b20. I added a secondary air inlet to the air cleaner and both inlets collect air right in front of the core support instead of the factory snorkel. K&N air filter, and now the exhaust. I'm up to a solid 27.5 mpg with two tanks so far and the power increase is amazing (almost all city driving). no flat spot before 2200 rpms anymore and it spins up VERY quick to 3200 rpm and redline. Noise wise its great a tiny bit louder than stock but just barely in the cab, hardly noticeable. Outside its a little throatier but not loud by any means. Before the old exhaust was a steady stream of hot air, now each pulse can be felt with your hand a foot back from the tailpipe at idle. Anyways it was pricey around 300 bucks including a new flex pipe but what a difference in drivability. this rig is beginning to have some get up and go, gets up to freeway speed quite nicely, strong passing power... oh the 4:10s helped out big time as well, lets the torque do what its supposed to. Down the road I see an electric fan, evans coolant, a n/a head i have with the bigger valves, maybe intercooler and a slight fuel adjustment... Oh to have more money and time.
Anyhow my 2 cents.
Hope to see some of you at the west coast meet
pup daddy
Re: 2.5 inch exhaust review for c223t
Postby pup daddy » Sat Aug 30, 2008 10:21 pm
sounds great! I did a ram air setup, k&n filter and a straight pipe prob 10 years ago and it was a great power increase, I cna only imagine how good it would feel on a turbo-d.
pup daddy
1990 chevrolet 454SS pickup
1983 Mercedes 300sd
husq_tech74
Postby husq_tech74 » Sun Aug 31, 2008 7:45 am
Pup daddy,what size pipe did you use on your n.a. engine? The muffler is shot on my 86,and the tail pipe is non-existent. So since I've got to replace all that,figgered I'd replace the whole exhaust with a larger diameter pipe. Also,did you utilize the flex section from the stock exhaust?.
Kal
    82 Luv 4x4 diesel=parts truck
    86 Pup diesel automatic=new purchase,project
bellavesus
Postby bellavesus » Sat Sep 20, 2008 1:28 am
hey, could you post a pic of the air setup you did? i would like to go that route and im curious how yours looks. i did the straight pipe as well and it definitely helped on the power.
86 Trooper, now with 4JB1TC!
89 Trooper, 2.223t swap
thenextone
Postby thenextone » Sun Oct 12, 2008 7:53 am
could you guys post some photos please
1981 isuzu pup 4x4 project for now
1982 isuzu pup engine and tranny (pending)
1995 isuzu npr biodiesel
2001 dodge ram 4x4 biodiesel
1981 Isuzu pup 4x4 biodiesel daily driver more power than a turbo dont know why ?
Return to “Diesel - Performance Mods & Upgrades”
Users browsing this forum: Google [Bot] and 2 guests
