installing a turbo to non turbo c223 engine
bizz80
Isuzu vehicle(s): isuzu trooper
Postby bizz80 » Sat Oct 28, 2017 5:02 am
i have an 85 trooper with c223 engine install. i was thinking of installing an ihi rhf5 turbo on it. i've never install an turbo to a non turbo engine before. can i just install the turbo without any modification to the engine? from the spec, c223 and c223T have the same compression ratio.
Re: installing a turbo to non turbo c223 engine
Postby Halden » Sat Oct 28, 2017 10:05 am
Many people here have done it. I have never done it... Nor am I an expert. But there are several writeups here as to how people have done it. I think most people just turn up the fuel screw is my understanding.
DieselJeep
Postby DieselJeep » Sun Oct 29, 2017 6:42 am
Diesels are "easy" to turbo, as far as compared to a N/A gas motor.
Especially mechanically injected diesels, as pretty much all factory N/A diesel bits can work well with a correctly sized turbo(both turbine and compressor wheels and housings).
Results vary with realistic goals, factory bits availability, money, skill, time, design of entire system, quality of aftermarket parts used, money, skill, time, determination, personal research invested, and money, skill, time.
Unskilled, uneducated, inexperienced, tools/facilities lacking, and faint of heart, be warned:
All vehicles are hunks of crap. Designed by individuals, the majority of which, have never turned a wrench.
Which one do you want to fall in love with?
robgt22
Isuzu vehicle(s): 95 honda passport, c223 swap. 01 trooper, 4jg2 swap
Postby robgt22 » Sun Oct 29, 2017 11:36 pm
Yes it can be done. I installed a Garrett gt1749 on my c223 5k miles ago. It's amazing how different the engine feels. How much boost are you planning to run?
95 passport with a c223, bolted to a gasser mua5. Garrett gt1749, 15 psi of boost. Straighpiped and intercooled. 2.5” suspension lift and 1.5” body lift, ball joint flip, 1 1/2” diff drop. 33x12.5 R15 tires, 12000 pound winch.
01 Trooper with a 4jg2 swap
bizz80
Postby bizz80 » Sun Oct 29, 2017 11:47 pm
so, basically, you can just install a turbo on a NA diesel engine wihout any major modification?
the ihi turbo is the only part i have lying around, and doing any major internal and injector bit on c223 engine just not worth it.
thx
robgt22
Postby robgt22 » Sun Oct 29, 2017 11:49 pm
bizz80 wrote:so, basically, you can just install a turbo on a NA diesel engine wihout any major modification?
thx
The na pop off pressure works with the turbo perfectly. I didn't raise my pop off pressure nor modified my engine internals. I installed the turbo, turned the fuel load screw about 1/4 of a turn and that was it. Finding a good location was the harder part due to space.
bizz80
Postby bizz80 » Mon Oct 30, 2017 12:02 am
robgt22 wrote:Yes it can be done. I installed a Garrett gt1749 on my c223 5k miles ago. It's amazing how different the engine feels. How much boost are you planning to run?
i'm not planning on adding too much boost. to honest, i'm still searching on how much boost the ihi rhf4 turbo makes.
robgt22
Postby robgt22 » Mon Oct 30, 2017 12:06 am
I'm by no means an expert, but maybe my post on installing the turbo can help you. viewtopic.php?f=19&t=24548
bizz80
Postby bizz80 » Mon Oct 30, 2017 12:12 am
robgt22 wrote:I'm by no means an expert, but maybe my post on installing the turbo can help you. viewtopic.php?f=19&t=24548
nice work! thanks. :D :D this is going to help alot.
Jakestewart82
Isuzu vehicle(s): 1986 isuzu trooper ii diesel
Postby Jakestewart82 » Thu Nov 02, 2017 2:58 pm
The connecting rods aren't very capable of holding the extra pressure.. they had a long run with converting these to turbo..
joeshmoe44883
Postby joeshmoe44883 » Thu Nov 02, 2017 4:48 pm
Jakestewart82 wrote:The connecting rods aren't very capable of holding the extra pressure.. they had a long run with converting these to turbo..
But interestingly the rod problems were only with the turbo engines from the factory. There have been many others who have turbod their na motors and havent had any problems.
2 86 Trooper II diesels, one 4 door the other 2, both projects.
86 Jeep Cherokee Pioneer with factory 2.1L turbo diesel.
05 Jeep Liberty Limited with 2.8L diesel (totaled)
06 Chevy Silverado with duramax
2014 Jeep Grand Cherokee ecodiesel
Postby puttputtinpup » Thu Nov 02, 2017 5:17 pm
Adding a turbo to an NA c223 isn't all that risky if planted into a 2wd, from what I've heard from Jerry Lemond. One of the weak links in the turbo c223 in a trooper or 4x4 truck was over-reving while in lowrange. They'd throw a rod.
Leaky turbo oil seal leaking into the intake was one other weak links for the turbo engine...Again, over-reving from a runaway engine (running off its own oil) killing the rods
robgt22
Postby robgt22 » Fri Nov 03, 2017 9:48 am
Actually the na rods are beefier than the turbo first gen rods, they look a lot like the 2nd gen. The problem was over revving and the governor not being able to react fast enough. Just keeping the red line below 4000rpm will give it a decent live after adding the turbo.
robgt22
Postby robgt22 » Fri Nov 03, 2017 9:52 am
Here's a post with the differences between the rods. //viewtopic.php?f=1&t=18201
