Transfer case model??
Josecarlos
Isuzu vehicle(s): M38A1 isuzu 4FB1 engine
Postby Josecarlos » Mon Oct 09, 2017 6:54 am
Good day sir
Can somebody help me identify what kind of transmission and transfer case this is i saw this from a junkyard in our place and i am planning to put this in my isuzu 4fb1 engine, the person from the junkyard told me this came from an isuzu trooper but this one is a cast iron and i dont know if this one will mate from my engine hoping for your reply thanks and good!
Isuzu??
Josecarlos
Postby Josecarlos » Wed Oct 11, 2017 1:02 am
Good day Sir!
I dont know if it is allowed to post this thread here i just want to ask the isuzu experts here what kind of transmission and transfercase i got from a junkyard in our place, i have a jeep m38a1 and planning to swap my newly accquired isuzu 4fb1 engine i want to retain the 4wd for farm use the transfer case came from a trooper but i dont know what engine. hope somebody could explain to me the model and if it is good for transmission swap to my jeep. Thanks and more power to this thread!
Re: Transfer case model??
Postby JoeIsuzu » Wed Oct 11, 2017 7:28 am
Jose,
There’s no need to create multiple posts. I merged the two into one thread and updated the Subject.
If the housing is cast iron as you said, this transmission was never offered on US P’ups. It looks like the MUA-5. If so, It is a bigger transmission than the ones used in P’ups. The bolt pattern should match your engine, but I don’t know about flywheel and clutch compatibility. Maybe someone else will know. Your questions are visible to the whole forum community — there is no “Sir” here. ;) Hopefully, someone will be able to help.
Postby puttputtinpup » Wed Oct 11, 2017 5:18 pm
Looks like cast aluminum to me
Postby Halden » Wed Oct 11, 2017 7:31 pm
puttputtinpup wrote:Looks like cast aluminum to me
but the transfer case at the back is rusted so it has to be iron or steel... or something that turns brown when it oxidizes... :mrgreen:
83 LS Long Bed Diesel
Postby puttputtinpup » Wed Oct 11, 2017 8:15 pm
Point taken. It'd be nice to have a few different views of it though
Josecarlos
Postby Josecarlos » Thu Oct 12, 2017 4:32 am
What i mean the transfer case is the cast iron the transmission is cast aluminum. Thanks for the reply. Maybe if not possible to match the tranny to my engine. Is there any removable bellhousing that could match my 4fb1 so that i will just use my old transmission from my jeep? I will just fabricate a plate from transmission to bellhousing.
Postby puttputtinpup » Thu Oct 12, 2017 7:04 am
As jack mentioned, your little diesel is the same bolt pattern at the gasser engines and this tranny has the starter on the correct side. Clutch, flywheel, and pressure plate might be the challenge...But then maybe not. Jerry Lemond would know.
JLEMOND
Postby JLEMOND » Thu Oct 12, 2017 6:47 pm
THAT TRANS MISSION IS A 4 SPD, WITH T/CASE BUILT ON THE BACK END AND WAS USED IN THE 84-85 TROOPERS AND THE 81-85 PUP GAS ENG VEH , SLIGHTLY DIFF AT THE FRT END FOR THE DSLS. AND IT WILL BOLT RIGHT ON THE 4FB1 BY USING THE 4FB1 FLYWHEEL AND CLUTCH AND PRESSURE PLATE ASSY . MUCH BETTER TRANS THAN THE 5 SPD THAT REPLACED IT IN 86-87
Josecarlos
Postby Josecarlos » Fri Oct 13, 2017 12:57 am
Thank you! I was so close of not taking the trans luckily i was able to take it! If not from this forum anyways i will have to take it apart and check for any problem! Thanks to you all guys :) :wink:
