Re: Manifold Flange
Re: N/A P'up Turbo Conversion Photos
Postby Paul » Tue Jan 20, 2015 12:34 am
Here are two shots of my (formerly) n/a truck with the turbo installed. Both manifolds are stock from a Trooper that had thrown a rod. It is hard to see the manifolds due to all the plumbing.
The conversion was done in 1995-96 with 110k miles on the truck. It has 202k miles now and has had no problems with the engine. I have worked on the tranny a few times.
joeshmoe44883
Postby joeshmoe44883 » Tue Jan 20, 2015 8:12 am
Beautiful!!
cecildiesel
Postby cecildiesel » Tue Jan 20, 2015 10:12 am
WOW that is clean!!
OzarkDaredevil
Postby OzarkDaredevil » Tue Jan 20, 2015 11:45 am
joeshmoe44883 wrote:Beautiful!!
^^^ What he said!
Postby Halden » Tue Jan 20, 2015 2:14 pm
that's disgustingly clean! Beautiful work, Paul!
-Haden
83 LS Long Bed Diesel
Postby Paul » Wed Jan 21, 2015 12:00 am
All--
Thanks for the kind words.
Postby JoeIsuzu » Wed Jan 21, 2015 9:08 am
Paul, is that an additional oil separator in the line that vents crankcase gases back to the intake?
ronster
Isuzu vehicle(s): 1982 Longbed, 5 Speed, Diesel
Postby ronster » Wed Jan 21, 2015 4:28 pm
That thing looks like it was cleaned with a toothbrush. It is one thing to have a clean install, but that engine bay is unbelievable!
Just curious about three things.
1. Are you plumbed to a front mount intercooler.
2. Is your intake charge to the turbo coming off of the driver's side and if so where is your air filter.
3. What type of piping did you use (the gray pipe)
Tx Ron
82 Isuzu Pup Dsl, 2wd, 5sp, Lb - 215k mi
63 Ford Falcon - 423k mi
00 Toyota 4-Runner SR5 - D4D 1KD-FTV converted - 133k mi
97 Toyota 4-Runner SR5 - TRD supercharged - 98k mi
02 Subaru WRX - TurboXS Stage 2 kit, - 140k mi
nucleus
Postby nucleus » Wed Jan 21, 2015 6:12 pm
ronster wrote:This one belongs to Nucleus. There is not a P'up in the photos, but has some of the best shots of the stock manifold. The rest of the build is still in progress.
Here is the thread: /viewtopic.php?f=19&t=20481
Stock turbo manifold.
This project is finally moving forward again! See this thread for pix on the liquid cooled mods, etc for the GT1548!
viewtopic.php?f=4&t=21966
1991 4X4 Pickup powered by a Gen 3 Trooper Turbo Diesel engine built by Jerry Lemond. 5 Speed Trooper MSG tranny behind the engine.
nucleus
Postby nucleus » Wed Jan 21, 2015 9:58 pm
Paul, WOW! That is beautiful!!
What's that extra sensor coming out of the upper thermostat housing?
Postby Paul » Thu Jan 22, 2015 12:04 am
Hey, you guys are noticing too many things :wink:
Jack-- Yes, that is a secondary oil separator. Both separators are drained back to the crankcase via the vacuum pump.
ronster-- Yes, the two gray pipes (2 1/4 inch aluminum) are feeding an intercooler up front. The cooler is from a Saab 9000.
-- The air cleaner is in the grey canister on the passenger side close to the firewall.
Ray-- The extra sensor in the thermostat housing is a temperature sensing thermistor to control the two speed electric fan.
And, I do sometimes use a tooth brush and lots of other stuff.
DieselJeep
Postby DieselJeep » Thu Jan 22, 2015 10:05 am
That is a very well executed, and well maintained project, Sir.
Beautiful work!
ronster
Postby ronster » Thu Jan 22, 2015 6:26 pm
That is an install worth making into a kit. Thank you for this submission. It was the goal of this thread.
jasonw86
Postby jasonw86 » Thu Jan 22, 2015 8:04 pm
ronster wrote:That is an install worth making into a kit.
:lol: I can only imagine the countless hours that Paul has into all of that work. That would be one spendy kit.
1984 diesel LS long bed 4x4
1983 diesel 4x2 long bed
Pupfocused
Postby Pupfocused » Thu Jan 22, 2015 9:54 pm
Every time I see Paul"s amazing pup I notice something I did not notice before. Very nice
Jim
1981 diesel pup(gone)
1985 4x4 diesel pup
1986 diesel trooper
