N/A P'up Turbo Conversion Photos
Re: N/A P'up Turbo Conversion Photos
Postby Paul » Fri Jan 23, 2015 12:04 am
Thanks again you guys. Your words are my reward for the work and time in this truck.
Ronster-- I just realized that the air cleaner is not visible in the posted photo of the drivers side so here is one of the passenger side.
Pupfocused
Postby Pupfocused » Fri Jan 23, 2015 10:36 am
Is that a back pressure gauge for the air filter?
Jim
1981 diesel pup(gone)
1985 4x4 diesel pup
1986 diesel trooper
ronster
Isuzu vehicle(s): 1982 Longbed, 5 Speed, Diesel
Postby ronster » Fri Jan 23, 2015 9:21 pm
Thanks for that last photo. Looks like your jack lost its home, but I like how you routed to the "cool" side of the engine for your intake air. I had a cruise control motor in that corner for a while. Nice for some of the long trips that were taken.
I guess the only other question is how much you had to do to fit the intercooler. I'm guessing it could almost fit in front of the radiator brace. Mine has AC which restricts things a bit. I don't see a compressor under your hood, wait - I don't see a hood or a prop rod. I'm guessing you don't have A.C. or that you have cleverly hidden it from the rest of us.
82 Isuzu Pup Dsl, 2wd, 5sp, Lb - 215k mi
63 Ford Falcon - 423k mi
00 Toyota 4-Runner SR5 - D4D 1KD-FTV converted - 133k mi
97 Toyota 4-Runner SR5 - TRD supercharged - 98k mi
02 Subaru WRX - TurboXS Stage 2 kit, - 140k mi
Postby JoeIsuzu » Fri Jan 23, 2015 9:55 pm
ronster wrote:Thanks for that last photo. Looks like your jack lost its home, but I like how you routed to the "cool" side of the engine for your intake air. I had a cruise control motor in that corner for a while. Nice for some of the long trips that were taken.
I'll spoil this one. Paul doesn't have a/c on that truck. The intercooler was modified some, and it takes the space where my a/c condenser sits. He still moved the grille forward just a little bit, but not that we'd notice.
I also had a cruise servo in that spot near the fuel filter, but it's been gone for a while.
Paul had a post waaay back about his turbo and intercooler setup. See THIS ONE. Unfortunately, the first image (from PhotoBucket) has disappeared. Maybe he still has it somewhere (Paul, if you do, just email it and I'll put it back into that spot).
Postby Paul » Sat Jan 24, 2015 1:59 am
Jim--
I think you are asking about the filter minder thingy next to the fuel filter. This is a pressure loss gauge with a memory so's you can decide when your fuel filter is getting plugged. The boss gave this to me :) These are made by Stanadyne and sold by most diesel fuel shops.
Ronster-- The intercooler is from a Saab 9000 and the core is perfect to front the P'up radiator. But the Saab cooler had plastic manifolds which did not suit the need so they were replaced with aluminum ones made from tubing.
Postby JoeIsuzu » Sat Jan 24, 2015 12:36 pm
Paul's missing image has been replaced. You can see the ductwork in the photo. Thanks, Paul!
There are some great shots of just the intercooler in THIS POST.
OzarkDaredevil
Isuzu vehicle(s): '81 Luv diesel 4x4
Postby OzarkDaredevil » Sat Jan 24, 2015 4:22 pm
The attention to detail you guys have borders on OCD! Simply amazing.
Tom
'81 4x4 diesel LUV - daily driver
81 LUV tdi
Isuzu vehicle(s): 81 Chevy luv Intercooled turbodiesel 85 S10 Intercooled turbodiesel
Postby 81 LUV tdi » Sun Mar 22, 2015 3:48 pm
Here are some pics of my S10 its a factoy diesel just put the turbo on a couple weeks ago
cecildiesel
Postby cecildiesel » Mon Mar 23, 2015 1:29 pm
THIS IS BRILLIANT!!!! The only thing I questions is the welding to cast. Now the welding to cast that I have done has been with cast chromium and all you have to do it getting it glowing hot and you can wire feed it. How did you do the welding?
81 LUV tdi
Postby 81 LUV tdi » Mon Mar 23, 2015 3:11 pm
I heated up red-hot then I Weld it with a wirefeed and when I'm done welding I keep it hot for approximately five minutes or so red-hot then I let it start cooling down slowly keeping it hot when it's all done I check for warpage usually you have some then I will usually either file it or I bolt it to the head and reheat it red-hot and tighten down the bolts this was my fourth one and haven't had any problem with any of them yet.
ronster
Postby ronster » Mon Mar 23, 2015 9:17 pm
Thanks for posting. Another one to keep us jealous.
Godiesel
Postby Godiesel » Tue Apr 07, 2015 6:59 am
Here's a few quick pictures of my setup. It's being swapped into a 80 LUV. I Should have it on the road next week.
80 Chevy Luv c223 tubo diesel with T5 5 speed swap.
80 Chevy Luv 4x4 currently resting
PUPdiesel
Isuzu vehicle(s): 1986 Isuzu Trooper II diesel
Postby PUPdiesel » Sun Apr 19, 2015 10:55 am
81 LUV tdi, if I sent you a manifold do you think you could weld me on a flange? And is it a t3 size flange?
265/75/R15 tires
Centerforce dual-friction clutch
w/ 81 C223, needs a turbo!
ronster
Postby ronster » Sun Jul 19, 2015 12:07 am
Godiesel, any update? Sounded like you were close in your last post.
ronster
Postby ronster » Sat Oct 31, 2015 9:49 pm
Been a while since this thread experienced any action. As my desire to add a turbo has not been satisfied I did some more internet research. Here are a couple of links from the Luv truck forum. We had pictures earlier, but their forum tells more of the story:
Yellow engine on the black '79 Luv:
http://forums.luvtruck.com/viewtopic.php?f=14&t=18535&p=138623&hilit=Turbo#p138623
http://forums.luvtruck.com/viewtopic.php?f=14&t=26409&p=199029&hilit=Turbo#p199029
Godiesel's thread (pictures are directly above) that engine is a transplant of a transplant and included a custom intake as well exhaust: http://forums.luvtruck.com/viewtopic.php?f=14&t=28012&hilit=Turbo&start=0
