Using c240 parts to turbocharge your c223
OzarkDaredevil
Re: Using c240 parts to turbocharge your c223
Post by OzarkDaredevil »
I've been thinking that the 1548 might be the one I end up using. $1,000 is high for that unit. I'm very interested in your project. Think the C240 exhaust manifold would interfere with a stock C223 intake?
joeshmoe44883
Post by joeshmoe44883 »
I found the 1548 on a couple other sites for $640. That's new, if one had the time they could probably pick one up off eBay used for 1/3-1/2 the price. I haven't mocked everything up yet on a head, I'll do that once i get the manifold drilled and tapped. I don't think the manifold will be a problem though, we'll see. My goal here is to build a factory looking, better-than-factory performing, yet affordable turbo kit.
lserd.oldrp
Post by lserd.oldrp »
if it's any help I put a a/r51 garret that came off a perkin's diesel on a n/a c-223 no lag 15 lbs easy. and with fuel turned way up makes 23 lbs at the drag strip run's great. I can get the numbers to you if you need them
1984 Isuzu pup N/A 2.2 Diesel 5 speed 3.42 gear Short bed.
Up grade's gt2052 turbo, 86-87 volvo inter cooler, 4'' cold air intake, 3'' Exh. aero diesel turbine muffler.
joeshmoe44883
Whats the make and model of the turbo? Does it have the 4 bolt t25 inlet flange and the 5 bolt discharge pattern? I'm looking for a turbo that is a drop in replacement/ upgrade for the factory 223t. Most are capable of fabbing stuff up to retrofit a different turbo, but a direct bolt on will save time and money and is alot more convenient.
joeshmoe44883
Started machining the exhaust housing. I machined the the face of the flange flat so that the turbo would sit flat and seal up good. I then drilled the 4 holes that will be tapped and studs installed. Next I started milling out the hole into a rectangle to match the turbos rectangular inlet. I seriously underestimated how much material had to come out, so far I've spent around 3 hours on it, probably have another 6 to go. If this proves to be a good candidate for turbo conversions, I'll look into some new tooling that could cut that time down to half or more. The housing could be used stock, but opening it up and matching it to the turbo will keep the backpressure low.
Flange is decked and holes drilled ready to be tapped for studs. I'll get a pic of it in the middle of it getting milled out to match the turbo.
joeshmoe44883
FlukeGE
Post by FlukeGE »
Looking good! How is the old cast cutting?
Ryan
1986 Trooper Gen III
1999 with 4JG2 Coversion
joeshmoe44883
Not too bad, I'm using HSS end mill in the pics. I think if I invested in a carbide tipped unit I could really speed through it. At the moment I'm only taking off .010" on every pass, and going down 1.75-2". It takes awhile.
OzarkDaredevil
Joe,
Question: any chance opening the exhaust that much will reduce exhaust pressure/velocity to the point of having a negative effect on turbo spooling?
joeshmoe44883
Tom,
I don't think so, because the turbines exducer is still the same size. Plus I'm only matching the manifold to the turbo. I would compare it to a garden hose with a spray nozzle on the end. Now take away the garden hose and adapt a 4" fire hose to it. Only so much water can come out of that nozzle no matter the hose size.
OzarkDaredevil
joeshmoe44883 wrote:Tom,
Yep. I see now. Keep us updated on your progress!
Hawaii50
Isuzu vehicle(s): Trooper diesel motor in a Naissan Hardbody
Post by Hawaii50 »
I just found a c240 in an old generator. Is it a good candidate to turbo charge and put in a truck?
1988 Nissan D21 pickup with a C223T
I wouldn't plan on getting it on the highway, the redline is only 3 grand.
Halden wrote:I wouldn't plan on getting it on the highway, the redline is only 3 grand.
Highway? He's in Hawaii. :lol:
Hawaii50
Post by Hawaii50 »
what can I do to make it a higher rpm motor? Im not worried about pulling it apart and buying some parts.
