Out with the old and in with the new.
20LBS BOOSTER 85PUP
Re: Out with the old and in with the new.
Post by 20LBS BOOSTER 85PUP »
Only 30+ hours? I'm in line to do the same when I find Spacecab body.Details and pictures would help much.
heathw
Isuzu vehicle(s): 91 Pickup 223 diesel conversion
Post by heathw »
I got most of the details from here, but if there is something I can help you with let me know. Wiring was the hardest to me. I believe most that did the transplant removed the old wiring harness and installed it to the 90 model.
91 Isuzu p/u Converted to 223 diesel
Youngcummins
Post by Youngcummins »
i can get the part # for the 12 volt set i got online from a thermo king dealer out of OR but they were only $17 for the set and have done fine for the few months they have been in.
My rig
1996 Ram 2500 Cummins, 414K miles
2000 S10 reg cab long bed with a 81 LUV c223 5 speed, the runt of the fleet, but the most driven.
2003 Jetta GLS TDI 5sp, 53mpg!!!
heathw
Post by heathw »
Here is some pics of the truck in the day light. I took pics of the shims under the motor mounts. I have noticed that the truck is lower geared, but still runs great!!! I haven't figured out how to fabricate a mount for the compressor. Anyone have any ideas?
heathw
Post by heathw »
YoungC,
I may need to get with you when these burn out. Thanks
the 91 should have had 4.10 rear end and the engine probably screams a little @ 60-65, doesn't it?
heathw
Post by heathw »
puttputtin,
yes can I swap the old rear end or the ring n pinion?
heathw
Post by heathw »
I should have updated here on the AC upgrade.
trooper T/diesel
Post by trooper T/diesel »
the 91 could have a Isuzu 10 bolt or a GM10 bolt.
if its an Isuzu rear end, it will swap best i know.
a GM diff is a no--go
but if the old pup/luv was a 4wd or a auto trans don't do it, it will be a 4.11 same as what the 91 has.
hearsthe
weather forecast for NW OR
I was curious about the alternator hookup. Was the harness plug-n-play? An engine swap like this seems more & more appealing.
heathw
Post by heathw »
Trooper T - I guessing it has an Isuzu rear end because it come apart from the drive shaft side.
puttputting - Not exactly plug and play. Four wires total. Two are obvious and the other two........well if you get them wrong your dash lights stay on and the motor will not shut off with the key. :)
heathw
Post by heathw »
It is hard to believe this was 10 years and 80,000 miles ago.
heathw wrote:It is hard to believe this was 10 years and 80,000 miles ago.
Yes, it is!
DieselJeep
Post by DieselJeep »
Isuzu Diesel are awesome. And so are well thought out, planned, budgeted retrofits that are done with skill.
