Diesel swap into 84 GMC S15
Dick'sdiesel
Isuzu vehicle(s): 84 pup diesel
Post by Dick'sdiesel »
Will a 2.2 diesel and 5 speed manual from an 84 pup "easily" swap into an 84 GMC s15 with 2.8 and auto trans. Gen instructions would be much appreciated. Was hoping not to have to fabricate parts myself. Thanks
Re: Diesel swap into 84 GMC S15
I'm not sure if any of our members have done such a swap. Gm had a few GMC and Chevy s10 come factory with the Isuzu 2.2 but were equipped with a different transmission, separate belt driven vacuum pump, and since your gmc is a gasser, you'd need to make the glow system functional in a gasser truck
You'd probably have to find or fabricate motor mounts and a transmission mount. Andy raises a good point about the electrical system, but I doubt the wiring would be that big an issue. The Isuzu shifter might not be exactly where the original one was. You'd have to figure out how to hook up the cooling system -- but frankly, I think I'd rather deal with plumbing the P'up engine than trying to find a GM water pump for it. They're pretty much unobtatium.
Airplanedoc
Isuzu vehicle(s): 1987 Pup 2.2 diesel with 4 speed, 2007 Ram Mega Cab with long bed conversion 5.9 diesel
Post by Airplanedoc »
The oil pan is different on the 2.2 S10 engine you’ll have to modify it.
