Opel campo intercooler mod?
Opelcampo99
Isuzu vehicle(s): Isuzu(opel)campo 99 2.5 TD 56Kw
Postby Opelcampo99 » Mon Dec 04, 2017 11:56 am
Hi,first post here
I own an opel campo sportcab 4x4,same engine as isuzu 2.5 td (56 Kw,76 hp)
Can I install an intercooler?
Opelcampo99
A question about modding
Postby Opelcampo99 » Mon Dec 04, 2017 12:42 pm
Hi,I own a opel campo pickup sportscab,same engine as Isuzu, 2.5 td (56 KW,76 Hp)
Can i mount an intercooler on it?
robgt22
Isuzu vehicle(s): 95 honda passport, c223 swap. 01 trooper, 4jg2 swap
Re: A question about modding
Postby robgt22 » Mon Dec 04, 2017 12:54 pm
Opelcampo99 wrote:Hi,I own a opel campo pickup sportscab,same engine as Isuzu, 2.5 td (56 KW,76 Hp)
Yes, you can, but do you know how much boost are you running? If you are running <7psi you're safe, if you are planning to raise your boost then an intercooler is a must, you can decide whether to mount it on top of the engine which I think was the 2.5 stock location, or at the front.
95 Honda passport with a c223 swap. Garrett gt1749, 15 psi of boost. Straighpiped and intercooled. 2” lift, ball joint flip, 1 1/2” diff drop. 33x12.5 R15 tires, 12000 pound winch.
01 Trooper with a 4jg2 swap
Opelcampo99
Re: Opel campo intercooler mod?
Postby Opelcampo99 » Tue Dec 05, 2017 4:17 pm
Okay thanks, the turbine on my engine is the stock factory made but I only get 76 Hp.
My friend has a 2.5 diesel and it has same 76 hp,why is that.
I was thinking of putting a turbine from a 2.5 dti version of my car,this one https://www.auto-data.net/en/?f=showCar&car_id=26180
robgt22
Postby robgt22 » Wed Dec 06, 2017 11:55 am
Opelcampo99 wrote:Okay thanks, the turbine on my engine is the stock factory made but I only get 76 Hp.
Maybe you're not running enough boost, I don't think replacing the turbine is needed, install a boost gauge so you know how much boost you're running and then you can raise it and install an intercooler, it should give you more power.
Opelcampo99
Postby Opelcampo99 » Wed Dec 06, 2017 3:12 pm
It's the stock,factory built in turbine don't know how much I can boost it?
Postby JoeIsuzu » Wed Dec 06, 2017 3:50 pm
It would help if you’d tell us what engine you have.
Opelcampo99
Postby Opelcampo99 » Wed Dec 06, 2017 4:23 pm
It's the isuzu 4ja1-t 2.5 l td
robgt22
Postby robgt22 » Wed Dec 06, 2017 5:43 pm
I'm sure the stock turbine and compressor wheel are more than capable of holding 10+ psi of boost, but first install a boost gauge so you can work up from there.
Postby JoeIsuzu » Wed Dec 06, 2017 9:29 pm
Opelcampo99 wrote:It's the isuzu 4ja1-t 2.5 l td
According to wikipedia.org (sometimes unreliable, I know), there were several variants of this engine, depending on what country you're in.
But if you're not getting the power you'd expect, I'd begin by ruling out any mechanical or tuning issues. I would not begin to consider modifications to an engine that has performance issues. Troubleshoot -- THEN modify.
Opelcampo99
Postby Opelcampo99 » Thu Dec 07, 2017 4:56 am
Ok thanks for the info,another question how can I lift my pickup the cheapest way, can I put shock abosrbers from another car and if so what what kind of ones to lift it?
Postby JoeIsuzu » Fri Dec 08, 2017 4:50 pm
Opelcampo99 wrote:Ok thanks for the info,another question how can I lift my pickup the cheapest way, can I put shock abosrbers from another car and if so what what kind of ones to lift it?
You did well by creating a new topic for this question: viewtopic.php?f=19&t=25035&p=159353#p159353
Hopefully, all replies will go there, rather than here.
