Grindes when selecting 3rd gear 1992 rodeo 5-speed 2x4
Antonis
Isuzu vehicle(s): 1992 isuzu kb2500 single cabin 5-speed 2x4
Postby Antonis » Thu Dec 21, 2017 10:27 am
After behaving not so good at my transmission I noticed that when I am selecting 3rd gear it grinds.I also noticed that if I try to push the gear lever very gently, most of the times it doesn't grinds. Clutch is all the pushed by the way.Is it the synchro rings; I changed transmission 3 years ago so is there any solution except from replacing the gearbox;Will transmission oil change make any difference;
Antonis
Re: Hard at selecting 3rd gear 1992 rodeo 5-speed 2x4
Postby Antonis » Thu Dec 21, 2017 10:28 am
Double clutching doesn't help eather...
Postby Halden » Fri Dec 22, 2017 11:13 am
Antonis wrote:Double clutching doesn't help eather...
Not to be a smart alec... But are you sure your rev matching pretty dead on when you double clutch?
See if it does it from a dead stop as well... If it's hard to push if into gear at a dead stop you might have air in your line possibly
83 LS Long Bed Diesel
Antonis
Re: Grindes when selecting 3rd gear 1992 rodeo 5-speed 2x4
Postby Antonis » Sun Dec 24, 2017 1:08 pm
I don't know but the last few days it only grinds when 4th to 3rd at high speed (when 3rd is around 3000-4000rpm) Of I wait until the rpm drops in 4th gear (around 40kph)it shifts fine
