1.9L Rebuild
Blue83
Isuzu vehicle(s): 1983 P'up 1.9L
1.9L Rebuild
Postby Blue83 » Fri Oct 20, 2017 8:31 pm
Hey everyone,
I had messaged a few weeks ago asking about what a certain noise could have been coming from.. well, I found out. I guess my rod bearings had finally had enough and we're completely wiped out. I broke down the motor and sent it off to grind the crank and bore out the cylinders. It probably just needed a touch up, but I figured I'd do it right first than having to mess with this motor again in a few years. New pistons, new bearings, new rings! I am also going to run through the cylinder head and replace anything else that looks suspect. I'm cleaning out RockAuto's inventory for ignition/timing parts and gaskets :lol:
Anyone have any suggestions on things I should replace while I have it broken down?
I am also thinking about adding a small turbo! After being inspired by Kendall's motor. Does anyone know if he upgraded his valvetrain or rotating assembly to handle the boost? I didn't read anything about what he did to the head or bottom end. Thanks!
Crankshaft
All the rod bearings looked similar.
1983 P'up Longbed 1.9L Bagged and Bodied on 18" Centerline Razors.
