Ventilation blower won't run
aliciajae
Isuzu vehicle(s): 1995 Isuzu Pickup
Postby aliciajae » Sat Oct 14, 2017 3:48 pm
On my 1995 Isuzu pickup I am not getting any air from the vents. I have checked the fuse, replaced the relay, replaced the blower motor, and replaced the resistor. I have power through the resistor and still nothing. Any suggestions or ideas for me?!? Thank you
Reason: Subject change (was "No air coming from vents")
aliciajae
Postby aliciajae » Sat Oct 14, 2017 4:04 pm
I have a 1995 Isuzu pickup with no air coming from the vents. I have checked the fuse, replaced the relay, replaced the blower motor and replaced the resistor. I have power through the resistor and still no air flow from vents. Any suggestions or ideas? Thnank you!
dorf
Re: No air coming from vents
Postby dorf » Sat Oct 14, 2017 4:08 pm
Sometimes my 81 does that ......no air no nothing........
until the alternator spins up .....to operating voltage....to activate the relay
I'm not familiar with a 95......but maybe a missing ground
aliciajae
Postby aliciajae » Sat Oct 14, 2017 4:39 pm
Thanks for the reply. Is it possible that there could be a problem with the switch that controls the 4 speed settings?
dorf
Postby dorf » Sat Oct 14, 2017 5:15 pm
I guess the best thing would be to start checking voltage to the switch then use a jumper as appropriate to make it function
Sorry can't be of more help
Postby JoeIsuzu » Sat Oct 14, 2017 6:02 pm
Wait, are you saying the blower isn’t working? That’s a completely different issue from “No air coming from vents”.
aliciajae
Postby aliciajae » Sat Oct 14, 2017 7:05 pm
So the blower motor has power but it is not spinning. This is a brand new blower motor. I basically have nothing happening with the heater/ac.
Postby JoeIsuzu » Sat Oct 14, 2017 8:26 pm
aliciajae wrote:So the blower motor has power but it is not spinning. This is a brand new blower motor. I basically have nothing happening with the heater/ac.
Sounds like you may have replaced a perfectly good blower with a new one.
So is there current at the connector -- the last one that the blower connects to? If I recall correctly, it's a 2-wire connection rather one hot and a chassis ground. So be sure to ground your test lead via the wire, not directly to the body. You may have a bad ground.
aliciajae
Re: Ventilation blower won't run
Postby aliciajae » Sat Oct 14, 2017 8:59 pm
I also think I replaced a good working motor. I will check into your suggestion tomorrow. Thanks for the response.
sanramonrover
Isuzu vehicle(s): 1991 KB (AKA TFS) 4X4 with 4JB1 Diesel
Postby sanramonrover » Sat Oct 14, 2017 9:47 pm
Since the motor has been replaced, here is a possibility - and it DID happen to me on a vehicle I bought.
Assuming the fan motor is spinning but no air comes out - the fan, being a centrifugal type fan, had been put on the shaft backwards! Yup, it tried to pull air from the same place it was trying to blow air out.
1991 KB 4X4
1988 VW Westfalia
1975 Triumph Spitfire
