Transmission noises
robgt22
Transmission noises
Postby robgt22 » Wed Oct 11, 2017 10:20 am
It looks like my transmission is starting to say goodbye :cry: , when releasing the gas pedal in 2nd or 3rd gear, I can hear a weird noise coming from it, it sounds like a bad bearing but it's not a constant noise, it's more like a rythmic sound, could this noise be made by a bad drive shaft support bearing? I haven't crawled under my truck, but I'm expecting for a bad tranny :cry: . Can these transmission be rebuilt successfully? Or am I just looking for another one? I've read I can use one from a gasser and just swap the bell housing. I need to get my truck on the road as quick as possible. It's a msg-5 tranny.
95 passport with a c223, bolted to a gasser mua5. Garrett gt1749, 15 psi of boost. Straighpiped and intercooled. 2.5” suspension lift and 1.5” body lift, ball joint flip, 1 1/2” diff drop. 33x12.5 R15 tires, 12000 pound winch.
01 Trooper with a 4jg2 swap
