Accelerator pedal got stuck in down position - HELP
alfiedog
Postby alfiedog » Wed Jan 29, 2014 10:59 am
(Also posted at Plantetisuzoo.com)
I think I already know the answer, but want to run it by the board and all it's collective wisdom.
My son called me this AM from inside his pickup in downtown New Orleans. (It was 30 deg. F outside at the time.) I didn't get the greatest of details from
him but I think I got the gist:
-Apparently his gas pedal would not come back up after he started the truck, and the throttle was fully open by the revving he described.
-He also mentioned the cable was slack when he manually lifted up the pedal with his hand. (is this possible?)
-I'm not clear on how long he let the engine run at such high RPMs, but I think he may have started and restarted it a few times.
Anyway, while on the phone with him, he said it "fixed itself" and all was normal now. I stayed on the phone with him while he was driving to work and all
was good.
My guess, and hope, is that the throttle linkage(s) just need some oiling and that the cold weather made things "sticky" for a bit. I would like to address
this problem so it doesn't happen again; or in a more dangerous circumstance.
I'm going to advise him to put a little engine oil on all the moving parts he sees at the throttle linkage, including any exposed accelerator cable parts, unless
you folks give me reason to think otherwise.
Since I'm inexperienced in most things mechanical, your insights are of great value concerning all things Isuzu.
Thanks,
Joe
'88 Isuzu Pickup LS, 2.6L, EFI, 5 speed manual
Missouri
Morgan
Re: Accelerator pedal got stuck in down position - HELP
Postby Morgan » Wed Jan 29, 2014 11:32 am
I'm not sure if you will find this helpful or not. My truck does not have a manual choke. For cold starts, I pump the gas pedal twice then start the truck. Then it's a matter of waiting a few minutes as the engine warms and increases idle speed. Once the engine evens out, I tap the pedal and it bumps the idle back down. The first time someone experiences this (my roommate wanted to borrow the truck and caming running inside in a panic) it can be loud and scary as the engine revs up.
By the way, can your son please send the cold weather back? It's looking like May up here. :?
“Patience is the ability to idle your motor when you feel like stripping your gears.” ― Barbara Johnson
1990 Isuzu pickup 2.3L 5speed (George/Georgie)
ZedDee
Postby ZedDee » Wed Jan 29, 2014 11:43 am
With him revving out a cold engine he may end up calling you again for other problems in the future. Best advise him to stop that.
Anyhow is is most probable that the throttle plate got stuck open in the housing.
There is a throttle return spring that pulls back on the throttle cable and that is what returns it to rest position. If the plate is stuck, then the linkage won't return meaning the accelerator pedal stays down. The cable is thin and flexes so you can push back against it which is why he was able to lift it by hand.
It probably fixed itself either by the tension of the spring finally pulling it back or he pressed down on the throttle again and that shifted the throttle plate, freeing it.
Possible that the linkage nut needs looking at as it sounds like the plate is moving around. I don't think there is anything motor oil will help in this situation, Just some adjustment needed, or maybe he was pressing down on it with all his might? The motor oil might just attract more dirt and grit.
1994 Isuzu Pickup, 2.3 Carb, Regular cab, Regular bed, 2WD, Manual
Return to “General Troubleshooting and Maintenance”
