Steering Wheel Removal.
Richey
Isuzu vehicle(s): 90 Spacecab, 84 Pup, Diesel WVO
Postby Richey » Fri Aug 17, 2012 4:02 pm
I'm trying to remove the steering wheel from a 1984 LS P'up, No matter how hard I pull, It wont come off, Is there any tricks to getting this off?
1990 Spacecab 4x4 4 speed 2.2L Diesel. Complete Veggie oil conversion.
Get an Isuzu Key Lanyard:
http://www.isuzupup.com/viewtopic.php?f=10&t=17443&p=111177&hilit=lanyard#p111177
Darby
Re: Steering Wheel Removal.
Postby Darby » Fri Aug 17, 2012 4:24 pm
I've always used a steering wheel puller.
Kendall124
Postby Kendall124 » Fri Aug 17, 2012 4:34 pm
Sootfart covers this in the general "how to" section.
"Horn fix using a .22 shell"
viewtopic.php?f=38&t=15172
1986 Lil' Blue 1.9L Turbo
1st place, "Mini-Truck" Division. Greenwood Auto Show. Seattle / 2013
Sold to a young man in Spokane. He fell in love instantly
soot fart
Postby soot fart » Fri Aug 17, 2012 5:07 pm
Kendall Sootfart Jerry and Jerry Lemond Are not the same person. Jlemond is the go to Isuzu Parts and Knowledge guy. Though we are seniors and both good lookin. Jerry wears striped overalls and sootfart wears the solid blue. Sootfart Jerry
Have someone pull gently on steering wheel while you tap gently with rubber or plastic hammer all around the wheel. Done!
All the screws removed I hope?
Pupfocused
Postby Pupfocused » Fri Aug 17, 2012 9:19 pm
On my 85 pup took a piece of 1/4" steel 4"x 6" and cut a 1/2 circle notch out of the long edge about 1 3/4" wide and deep. I put the 1/4' steel behind the wheel and used a large gear puller to pull on the steel plate. It sounded like a gun going off when it came off. I have taken other wheels off with out using a puller. The trooper wheels have taped holes so you can use a normal steering wheel puller.
Jim
1981 diesel pup(gone)
1985 4x4 diesel pup
1986 diesel trooper
Richey
Postby Richey » Fri Aug 17, 2012 9:20 pm
soot fart wrote:Kendall Sootfart Jerry and Jerry Lemond Are not the same person. Jlemond is the go to Isuzu Parts and Knowledge guy. Though we are seniors and both good lookin. Jerry wears striped overalls and sootfart wears the solid blue. Sootfart Jerry
Yeah, I got it off, It just took a bit more muscle then I thought it would.
Kendall124
Postby Kendall124 » Sat Aug 18, 2012 8:28 am
Whoops! :oops:
Return to “General Troubleshooting and Maintenance”
Users browsing this forum: No registered users and 3 guests
