New owner; Mystery Fuel Line
Jyck
Isuzu vehicle(s): 1992 Isuzu Pickup 2.3L Manual
Postby Jyck » Tue Jan 12, 2021 9:05 am
Picked up a 1992 2.3l pickup. Test drove it and it ran well except for an erratic idle however after I brought it home and parked it there was a puddle of fuel.
Does anyone know what this fuel like connects to/comes from? (Attached image) My Weber 32 36 and Holley regulator is on its way but I want to identify this before I start the conversion.
Thanks in advance!
Re: New owner; Mystery Fuel Line
Postby Red Truck » Tue Jan 12, 2021 3:34 pm
Is that indeed a fuel line, or is it for vacuum? If it's vacuum, does it run a lot better if it's plugged? Where is the other end attached (maybe the fuel vapor canister)? Anything on the underside of the air cleaner it might fit with?
Also, just curious, but what's that steel tubing with the tee-fitting for, along the firewall? R/
'87 Isuzu p'up 2.3 gas, 5spd, 4WD, base model, Fed spec
Jyck
Postby Jyck » Tue Jan 12, 2021 9:15 pm
It’s definitely a fuel line as there was fresh fuel coming out of it.
The tubing is an air line for the air suspension.
Postby Red Truck » Tue Jan 12, 2021 11:45 pm
Hmmm...so where exactly is the other end of this fuel line attached? I believe the mechanical fuel pump only has one outlet to the carb, and it looks like it's intact.
Air suspension air line: got it, thanx.
