15"'s on a 4x4 Pup: what lift for proper clearance
Bellski
Isuzu vehicle(s): '81 P'up 4*4 4spd diesel shortbed
Postby Bellski » Mon May 21, 2018 11:53 pm
Hi, my PO put 15" wheels from an Xterra on my'81 4x4 pup. Which is fine...except for hard turns; they hit the frame. No bueno. My question is how much lift would i need for full clearance? I like the bigger wheels, but do lots of road driving.
Thanks....
Re: 15"'s on a 4x4 Pup: what lift for proper clearance
Postby JoeIsuzu » Tue May 22, 2018 12:28 am
Are the wheels hitting frame, or the tires? If it's wheels, I'm not sure how lifting it could help.
Bellski
Postby Bellski » Tue May 22, 2018 8:51 am
Just Tires. You would never know driving unless you are pulling an ectrwmwly tight turn or donut. Havent quite figured out pics yet but i ill try after work...
Postby JoeIsuzu » Tue May 22, 2018 10:21 am
Bellski wrote:Just Tires. You would never know driving unless you are pulling an ectrwmwly tight turn or donut. Havent quite figured out pics yet but i ill try after work...
What size are the tires?
pup daddy
Postby pup daddy » Wed May 23, 2018 9:09 am
Are you hitting frame or the bottom corner of the cab?
Turn up the torsion bars. Smaller tires are the only way to go. 215/70/15 won't hit except for sharp turns in a bump. I use 225/70's and just drive carefully. You can go with 235/70's but you will have to have an inset wheel. Anything larger will need a body lift or major suspension work, like a solid axle swap
1990 chevrolet 454SS pickup
1983 Mercedes 300sd
Bellski
Postby Bellski » Fri May 25, 2018 9:12 pm
Well it"s raining pretty good so no frame on tire pics yet...i tried and they were awful. But tires are 235 75R15 's, and here is a pic of what they look like on my ol gal. I am going for a functional, typical lift like you would see on an old 4x4 toyota hunting rig: not a mudder or rock climber, just enough to hit the old Forest Service backroads with more confidence and clearance, that's why i was hoping to keep the 15's.
But now I have bigger fish to fry. We will see how Cold Start Device tastes real soon :roll: . Been doing homework, what an insane amount of Isuzu Sensei level information here. So grateful. --Bell
hillbillie1
Postby hillbillie1 » Sat May 26, 2018 4:40 am
Bell,,,pull your wheel off and remove rubber splash guard.
You can drink coffee and do CSD at same time.
86 long bed diesel pup
86 turbo space cab Ls pup
Cummins 3500 4X4 6 speed Manual
2011 Limited Ultra HD
Postby oldestisuzuist » Sat May 26, 2018 11:33 pm
If your tire is hitting the frame a lift may not do much good. More backspace or positive offset moves the inside edge of the wheel & tire closer to the frame. If they're just barely hitting a 1/4" wheel spacer just might be enough to clear, but the bad news is they'll be more likely to rub the fender with a spacer. Try the lift 1st, then try the spacer, if it clears the frame then start trimming until it clears the fender.
luvcamas
Postby luvcamas » Sun May 27, 2018 1:40 pm
are you from aussy land. down under? always wondered if you guys were upside down
1981 2wd diesel LB
1981 4wd diesel SB
1982 diesel 4x4 SB
:mrgreen:
