2 inch lift
militarynut
2 inch lift
Postby militarynut » Tue Aug 28, 2012 9:29 pm
I'd like to put a 2 inch lift on my 82 diesel. I know in the back, new leafs and shackles will give me what I want but I have no idea how to lift the front without tightening up the torsion bars. HELP!!!!!!!!!!
Current Daiy Driver: 1982 Isuzu P'up Diesel "Mongo" DLX. 4X4, 4 speed manual.
(Qoute From Big Bang Theory): "A robot arm has a death grip on your junk. Ask anyone dude, that"s funny!!"
Re: 2 inch lift
Postby oldestisuzuist » Tue Aug 28, 2012 10:18 pm
One full turn equals about 1/4" lift.
Re: 2 inch lift
Postby JoeIsuzu » Tue Aug 28, 2012 10:39 pm
oldestisuzuist wrote:One full turn equals about 1/4" lift.
So, can he get 2" lift in front just by cranking the torsion bars up?
OzLuvTrucker
Re: 2 inch lift
Postby OzLuvTrucker » Wed Aug 29, 2012 5:02 am
For maximin lift flip your upper ball joints, remove downward travel limiting bumpstops, reindex your torsion bars and crank them up, do a diff drop to lessen cv angles.
1980 KBD40 4x4 ISUZU Tipper Trayback C190 Diesel Engine Torsion Crank 4.555:1 Diffs
Image Image
hunter3661
Re: 2 inch lift
Postby hunter3661 » Sat Jul 27, 2013 11:12 pm
If youre only going 2 inches why not just do a body lift instead of suspension? I just put a 2" body on mine and the radiator still lined up pretty well but I had to trim out around the shifter a little bit but still easier than a suspension lift.
91 pickup 4x4 3.1L
luvcamas
Re: 2 inch lift
Postby luvcamas » Sat Jul 27, 2013 11:54 pm
I just check with a company in Portland Oregon ( BENZ CO.)that re arches the rear leaf springs. They charge 65.00 per leaf spring. They told me 2" is no problem. But they said I may have some issue with the shackles :? Does anyone have a alternative to this , I just don't see another way of lifting the rear due to the axle is on top of the leaf springs. I have a parts truck , a 2wd , that someone lifted. They welded a box metal to the frame where the front and rear leaf spring mounts are. Pretty sano job, but I can't bring myself to do that on my 4x4 turbo/d truck. I want to keep it all stock or at least be able to put it back to stock if I do change it up .
1981 2wd diesel LB
1981 4wd diesel SB
1982 diesel 4x4 SB
:mrgreen:
hjalbert
Re: 2 inch lift
Postby hjalbert » Fri Aug 23, 2013 8:46 am
I guess I should have posted this topic in this forum. Here is a link. To lift two inches in the back all you need is shackles that are four inches longer. Here is the link. viewtopic.php?f=19&t=19231
As far as the front, what ozluvtrucker said works. You can start by just tightening your torsionbar bolts and seeing where that gets you. In addition to flipping the ball joints you can make, or possibly purchase ball joint spacers that further correct the angle. The ball joint mods do not give you any lift, they just correct the A-arm angle. The more you lift the front by torsion bars, the more your tires will angle in at the top, which is negative camber. A little negative can be a good thing, depending. In these trucks, since handling cornering isn't really their strong suit any way, I would rather have 0 camber to extend tire life.
1986 Samurai with C223
1988 Samurai
1981 Pup 4x4 R.I.P.
1986 Isuzu Trooper 2.3
1989 Isuzu trooper 2.8
2007 Toyota Yaris
Vw dasher 2 door diesel
1972 Chevy C10 long bes stepside
John Deere 5210
Re: 2 inch lift
Postby JoeIsuzu » Fri Aug 23, 2013 9:07 am
hjalbert wrote:I guess I should have posted this topic in this forum.
Got it.
hjalbert
Re: 2 inch lift
Postby hjalbert » Fri Aug 23, 2013 2:14 pm
Thanks Jack!
1988 Samurai
1981 Pup 4x4 R.I.P.
2007 Toyota Yaris
John Deere 5210
getsomesy
Isuzu vehicle(s): 86' TurboDiesel Spacecab 4x4 :D
Re: 2 inch lift
Postby getsomesy » Sun Aug 06, 2017 6:01 pm
militarynut wrote:I'd like to put a 2 inch lift on my 82 diesel.
Pretty sure it is "Mongo" that is now in my ownership, Tom. I bought it from a guy in anahiem who said he got it from his friend, who got it from his own dad. Is that the case?
Funny to see it pop up. It's good that I know it's name now, and it would be great to know more of the trucks history if you wouldn't mind tell By me about it. By the way, you forgot a big knife under the seat, and a 1/2" breaker bar in the engine compartment haha!
1982 Isuzu Pup 4x4 N/A. 129K+ Rust free and running slowly.
Had a VW Caddy 1.6; wanted 4x4, bench seat, truck frame. - Behold the PUP new to me at 128k
Currently working on giving it the TLC that's been forgone and getting to know it.
