Timbren helper springs?
- Isuzu vehicle(s): spacecab diesel Holden rodeo 1993, 1986 pup spacecab, 1987 pup spacecab
- Contact:
Hey everyone? Has anyone ever used the timbren IR100 kit on their pup or pickup? DId they work well? I've got an 86 spacecab I'd like to haul more in. Thanks!
converted '86 diesel spacecab
Re: Timbren helper springs?
I tried something similar......didn't work real well
Finally went to a spring shop....they replaced the OEM with a new replacement.....no more problems with a sagging rear end
I hauled lots and lots of wood
Just my 2 cents
Just my 2 cents
I had a set of them that I used with mine to haul water. They help a whole lot, and were easy to install. I'm parting that truck out now after the motor failed, so I have a set from an 83 pup if you"re interested.
1983 Isuzu P'up 1.9l gasser DLX w/ 4wd---out of service "zoeypup"
-Weber carb
-Timbrens SES rear suspension help (for water haul)
112,630 miles on it
No longer owning a 1990 Isuzu P'up gasser 4wd 2.6l I-tec EFI "utilipup"
-Weber carb
112,630 miles on it
