Stock air filter adapter for Weber 32/36?
Red Truck
Post by Red Truck »
If this subject is covered elsewhere, please enlighten me. I'm looking for an aftermarket stock air filter adapter for a future Weber DGAV 32/36 installation, on my 2.3 4ZD1. I want to keep the stock air cleaner (for various reasons) setup. The Redline kit looks too big at 5-1/8". I believe the Weber inlet is around three inches. I'd rather not have to cobble something together if there's already one available somewhere.
Re: Stock air filter adapter for Weber 32/36?
Post by oldestisuzuist »
http://www.carburetion.com/Products/Pro ... =99010.675
See if this might work, #99010.301 has a taller lip if your air cleaner clamps around the lip like a Chevy LUV.
If not Redline makes similar adapters for several different Weber to stock air filters but nothing specifically for any Isuzu products. You will need to match the diameter of the air cleaner throat & the attachment method to the adapter, then make sure you have enough hood clearance.
http://www.carburetion.com/Products/Pro ... =99010.302
This one for a Toyota might be better, it has the clamp rod socket if that's how your air cleaner housing atttaches.
Red Truck
Post by Red Truck »
Thanks, these are about what I was looking for. I figured there must be an adapter out there that would fit on an Isuzu, but made for a Toyota or Datsun or Suzuki/whatever, but I haven't had the luck to find one yet! The first one you mentioned might work; my air cleaner doesn't have the 'clamp and rod' type (but I'm familiar with those). I'd have to create some sort of vertical stud attachment for the centerhole wing-nut on my cover. Shouldn't be too much of a challenge. By the way, the address of that website is near where I grew up...spooky. Thanx again/
