turbo project
hagasn
Isuzu vehicle(s): 1991 isuzu pickup 2WD 2.3 4DZ1 engine
Re: turbo project
Post by hagasn »
thanks Halden
i am the original owner of a 1991 isuzu 2WD pickup. the rebuilt motor was bored .040 over with a Calmini camshaft and gemini turbo kit with intercooler. power to the wheels is handled by a centerforce gold clutch.
hagasn
Re: turbo project
Post by hagasn »
she's up and running, whoot! now I just have to put some miles on her, 500 or so, and it's turbo time.
hagasn
Re: turbo project
Post by hagasn »
the motor is so quiet with the over bore pistons and ported head and intake I was expecting more of a performance gain. at cruising speed if you let off and get back on the gas she is definitely more responsive. I'm just impressed with fact that she's no longer leaks oil, fuel or water.
hagasn
Re: turbo project
Post by hagasn »
it looks like i have a small weep from my oil gauge fitting. nothing like the leaks i've had over the past 25 years.
hagasn
Re: turbo project
Post by hagasn »
i decided to do my first oil change this weekend just shy of 500 miles. i went with Castrol full synthetic 10W 30 and a K&N oil filter.
hagasn
Re: turbo project
Post by hagasn »
almost three years and finally just now got around to turbo my truck :(
hagasn
Re: turbo project
Post by hagasn »
the turbo install is in its final stages. we’re switching to a smaller electric fuel pump. the gemini fuel pump is just too large for what i’m trying to achieve which is reliability. we also ordered larger main jets for the Weber carburetor. drive safe
Re: turbo project
That's a really nice looking install.
hagasn
Re: turbo project
Post by hagasn »
thank you
hagasn
Re: turbo project
Post by hagasn »
i finally have the truck back. she still needs larger primary jets to make her safer. in boost my ARF reads 12.5. i barely step on the gas and she’s through the gears and @ 55mph :) i replaced the spark plugs with NGK’s but i need to increase the gap. she’s my daily driver so i’m doing my best to keep her in one piece. i’ll keep you posted
hagasn
Re: turbo project
Post by hagasn »
so far so good i just replaced the plugs yesterday 222333 miles
GoofySplo0f
Isuzu vehicle(s): 1991 Isuzu Pickup 2.3L 4Cyl Dropped 3in blocks in rear, 2 Leaf springs out, Cranked front Torsion bars, Straight Piped
Re: turbo project
Post by GoofySplo0f »
Do you have any sources for finding a rebuilt motor? I have a '91 Pickup as well, motor is going bad quick and I need to replace.
hagasn
Re: turbo project
Post by hagasn »
I rebuilt the motor myself with the help from a friend
Re: turbo project
Good looking build, man. You really did a good job
lspower
Isuzu vehicle(s): 1981 luv
Re: turbo project
Post by lspower »
Where did you drill for the oil return in the oil pan for the turbo?
