IsuzuPup.com
"If there's ever a nuclear holocaust, the only thing left will be cockroaches and Isuzu diesels." (author unknown) This site is dedicated to the humble little Isuzu P'up.
It is currently Sat May 25, 2013 4:21 am
Forum rules
Please click here to view the forum rules
Post new topic Reply to topic  [ 12 posts ]
Author Message
PostPosted: Sun Feb 12, 2012 6:37 pm
Offline
Howdy Gang.
So first, a quick "thank you" for all of the info on this site. I'll sit and go through thread after thread finding out what to do and what's been done. Then I'll go pop the hood and, sure enough, just like they said it would be. I swear I have tools lying all around and my laptop sitting close by just in case I need to read the info again. Laptop's getting a little greasy.
Anyway, pulled the smog/air pump today. Piece of cake. I did the "crimp and put back in" method. Hell, 3 out of 4 of them were loose, almost completely out by themselves. After crimping it was tough to get them back in due to all the soot and carbon that was built up on the threads over the years. I thought I always had a manifold leak but turns out this is what I've been hearing. (That and the normal 1.9L lifter tick). Had to tweak the idle just a fuzz but that was it. Was very careful to torque the exhaust manifold bolts just a tad. I broke 2 heat shield bolts but no big deal. After reading all the posts, I'm dreaming of the Pacesetter header. (and the Weber… and the Offenhauser… and the Flowmaster… AND the….)
I also went ahead and pulled off the rotten muffler and replaced it with flex hose. I'm pretty sure it was the original. I turned it on end and I swear all its guts poured out on the pavement. The Honda tuner kid down the street gave me a resonator exhaust extension so I put that on just for kicks. Sounds pretty good. I'm amazed at how quiet it is in the cab. No more exhaust leak and I'm not sitting on top of that rotten old can. And yes, the CAT is still on. I'll deal with that when it's Pacesetter / Flowmaster time.
Here's some before and after pics. Note the radiator and the fan. Thanks again gang.
File comment: Before.
File comment: After.
File comment: Custom "one off" Flex Hose exhaust.
File comment: Rotten old can.
_________________
1986 Lil' Blue Gasser 1.9L/4sp. Weber/Pacesetter/Glass Pack.
3" static drop. Rollpan. 15" Smoothies
It will give them a reason to pull you over and then shoot you. Take your bag of weed and your cash. Serve and Protect. Jerry
Top
 Profile
PostPosted: Mon Feb 13, 2012 12:35 pm
Offline
nice! i removed mine over 17 years ago and my a/c stop working close to 10 years ago so i don't have a belt on the pulley. almost no engine drag :) an after market header would look nice under the hood.. just saying. drive safe
_________________
the original owner of my 91 Isuzu pickup. mods include Calmini header and camshaft, Weber 32/36 carb, Cherry Bomb muffler and a very tired Centerforce gold clutch.
Top
 Profile
PostPosted: Tue Feb 14, 2012 2:11 pm
Offline
I honestly wish I could remember the plugs that I bought to plug up the holes in the head. They were drain plugs from something entirely different that had the proper thread pitch and I had to turn down the flange on a lathe, but they work great and look a little nicer than cutting the tubes and crimping them, but at the end of the day that way is much easier than my way.
Top
 Profile
PostPosted: Tue Feb 14, 2012 6:39 pm
Offline
you can find them at a Lowes or Home depot near you. just bring that part in that you removed from the exhaust side of the head.
_________________
Top
 Profile
PostPosted: Tue Feb 14, 2012 8:52 pm
Offline
Yeah, I took one to the local Ace Hardware. I think it was a size 14 but the pitch they had were close but not close enough (1.25 & 1.50). They seem to be working for now. I think I'll loosen them and aim the crimped end down. I scratched the heck out of my arm on one today.
She sure runs better now. Long way to go though.
_________________
Top
 Profile
PostPosted: Tue Feb 14, 2012 11:21 pm
Offline
just go buy 1/4"npt plugs, i had 3 brass ones but need to find one more.
Top
 Profile
PostPosted: Tue Feb 14, 2012 11:52 pm
Offline
The fittings at the head are 14mmx1.25, same as a spark plug. The EGR bung is a 22mmx1.5.
_________________
Top
 Profile
PostPosted: Wed Feb 15, 2012 5:46 am
Offline
yep, +1. the first set i purcased were steel which i found in the pluming section at Lowe's. about a year later i had one back its way out and had to purchase a replacement. this piece was brass, which looked really kewl. good luck. drive safe.
_________________
Top
 Profile
PostPosted: Mon Apr 09, 2012 8:35 pm
Offline
for anyone having issues with the plugs backing out down the road you need to take the fittings to the plumbing department, i did this when i removed the egr on my 300zx turbo and the plumbing plugs taper down and will fit like a glove and never back out. gotta love the fact ace still hires guys that know stuff
i'm in the process of pulling my smog/egr outta the 88 i just bought so it was nice to see the pics and basic sizes i would need to plug the holes, thanks guys.
in fact im off to pull the pump now while i wait for my new radiator
Top
 Profile
PostPosted: Tue Apr 10, 2012 8:08 pm
Offline
hmmm the npt plugs that i have worked great, on everything on the truck
Top
 Profile
PostPosted: Mon Apr 16, 2012 6:31 pm
Offline
Kendall124,
Looks good, clean. I have looked at these pictures before but missed something. Dude, what happened to your fan? It looks about half its normal diameter. Like a crop duster that flew to low. Does it still cool well at low speeds?
John
_________________
1984 GMC S-15 Short Bed Pickup with Stock Isuzu 1.9L Gas Engine
with California Emissions and 4 speed manual
Top
 Profile
PostPosted: Mon Apr 16, 2012 7:50 pm
Offline
Hooray!!! Someone noticed!!! :shock:
Yeah, a friend was driving the P'up and rear ended someone setting this whole rebuild in motion.
The radiator was shoved right up against the fan (see pic above). In order to get her to turn over, I had to cut about an inch off of the tips of the fan blades with some dikes. It was rubbing just enough to keep her from firing. Then, using starting fluid, she fired up and I got her home.
Twas a sad day lads.
That was 9 months ago.
viewtopic.php?f=18&t=14054&hilit=ouch
What's really cool about you bringing this up is I just put a new (used) fan on her this weekend. Found a guy about 30 miles south who had one off of a 79 Luv. Cleaned up real nice and fits good. Threw some Ford blue on her too. Same original radiator with a few solders. Holds water just fine. I had tried a couple of aftermarket fans from Oriellys but man they looked so deadly.
Thanks for noticing. And no, it didnt appear to effect my temps.
_________________
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
