I put power steering on a luv 4 wheel drive
Purist
Isuzu vehicle(s): 1988 pickup
Post by Purist »
I had a 1980 luv 4 wheel drive. I went to the salvage yard and found a 4 by 4 Isuzu pup diesel. I bought the power steering system off the pup and put it on my l u v.
Purist
Re: I put power steering on a luv 4 wheel drive
Post by Purist »
Hit me up if you want to know how I did it
There's a BUNCH of parts on that engine that many of the people would need sooner or later.
Like:
RADIATOR even if it looks leaky but not smashed badly. Those are obsolete.
Oil filter cooler housing. Save the bolts
(A big one!): The thermostat housing... entire housing that bolts to the front of the head
Alternator w the vacuum pump
AC brackets and idler pulleys w brackets if there
Injectors, injector pump, steel lines, and the vibration insulators that hold them together
Fuel filter housing
Fuel cap (has three prongs on it)
Glow system controller on drivers side above hood release. Black box
Pull the valve cover and remove the rocker assembly. Buy it, and save bolts & every push rod also.
Grab the heater core if it looks okay and especially if it's made of metal!. Some der Luvs g pups had metal cores that can be fixed. They're +$300 new and getting harder to find.
Pull the drive shaft and get the slip yoke from it that slides into the transmission. Or get the whole driveshaft if not too much more. The slip yoke is essential for doing the 5 speed upgrade on the diesel 2wd.
Sun visors
Locking 4x4 hubs on the front if you have time and $
The exhaust manifold might also be worth something to someone too.
Probably more things I can't think of now
guslevy
Isuzu vehicle(s): 1986 Isuzu Pup Turbo Diesel
Post by guslevy »
In one world get the whole truck as a spare.
I would like to get a complete truck just for parts, you never know when you need one
