Jono's drift P'up
jonofd3
Wheels all painted in new colours :)
Postby jonofd3 » Sun Dec 25, 2011 6:18 am
Wheels all finished!!
Jono
jonofd3
Re: Jono's drift P'up
Postby jonofd3 » Thu Jan 05, 2012 1:10 pm
Well, got a slight update at last :)
Managed to finish constructing the rear end today and put her back on 4 wheels :)
Got 2 gussets to make up to brace the shock turrets to the chassis then all that's left is to make up some spacer shims to sit eather side of the rose joints, then roll her over and finish seaming up the joints that I can't get towhen it's the right way up!!
Then the wheels went on and it was put on the floor:
Jono
DoodooIsuzu
Postby DoodooIsuzu » Fri Jan 06, 2012 5:42 pm
What car do those coilovers come out of? Have you had driveshaft clearance issues yet?
92 pickup with a KA24DE! Lowest static truck in town. Rodeo goodies all over.
jonofd3
Postby jonofd3 » Sat Jan 07, 2012 11:57 am
propshaft & axle clear everything fine, although there is only 60mm clearance between the axle and the chassis, but not expecting the suspension to move any more than 30mm from it's static position ;)
These coil overs have been superceeded already and they have only been on there 3 days! LOL They are from a TVR Cerbera, but I've just got a set of Gaz Gold fully adjustable shocks from a TVR Tuscan to go on instead, so this will allow me to raise and lower it as I need to ;)
Well today I needed to work under the truck to finish off the welding..... unlike normal people who would jack the truck up or put it on a ramp to finish off, I did it a little different :)
truck all prepped to weld:
Then needed to weld in other places, so over she went again :)
All the welding finished on the chassis it's time to prime the underside for it's colour :)
So tomorrow the chassis should be all green and the truck back on it's wheels ready for the mods on the front suspension :)
Jono
fallguy
Postby fallguy » Sat Jan 07, 2012 7:38 pm
That's the most awsome way I've ever seen to weld on the under side of a truck!!!!!!!
91 isuzu pickup dropped 8" all around,weber carb,header,96 tacoma front bumper. i drive it like i stole it cuz thats the way she likes it!...no bags,no switches,just hammered!!!
DoodooIsuzu
Postby DoodooIsuzu » Sun Jan 08, 2012 10:33 am
Haha this is pretty much my favorite build thread ever!
jonofd3
Postby jonofd3 » Sun Jan 08, 2012 11:39 am
Threw a bit of paint at it today :)
Undersealed the cab to get it black, painted the chassis and axle in the green then back on it's wheels!!
Jono
jonofd3
soot fart
Postby soot fart » Sun Jan 08, 2012 11:54 am
Did you get that paint free or are you colorblind. Jerry heheheheheh
Just kidding you, looks like good clean fun to me!
jonofd3
Postby jonofd3 » Sun Jan 08, 2012 1:01 pm
haha, not colour blind matey, but it was free ;)
all will become clear when it's finished :)
Jono
kristiferrandall
Postby kristiferrandall » Fri Jan 13, 2012 4:50 pm
looks good.
jonofd3
Postby jonofd3 » Tue Jan 24, 2012 2:04 pm
Well, a long over due update here!!
The rear end is all finished now with the new adjustable coilovers fitted, and another brace from the suspension arm crossmember back to the chassis just to be sure nothing moves under power or while drifting also stiffend things up a touch too!
Then I moved on to the front suspension as I'm going to be running coilovers up there too :)
Anyway, to give myself some clearance between the anti roll bar (sway bar) and the steering I am moving the bottom ball joint from under the arm to on top, along with a 25mm spacer which is also going to give me an extra 40mm track eather side!
This is roughly where the shock is going to sit
and the top mount for the coilover on the front end
And the new top arms for the front which will mount eather side of the coilover:
I've given the welds another going over so they are propper strong now and look prety sweet :) all thats left to do is paint them and they are set to fit :)
Jono
Jeremy_Worden
Postby Jeremy_Worden » Tue Jan 24, 2012 2:16 pm
awesome
kristiferrandall
Postby kristiferrandall » Tue Jan 24, 2012 7:32 pm
Wow nice.
jonofd3
Postby jonofd3 » Fri Jan 27, 2012 3:25 pm
Suspension arms all painted up, and also go tthe ball joint and track spacers all finished up ready to bolt on :)
Jono
Return to “General Performance Mods & Upgrades”
Users browsing this forum: Google [Bot] and 1 guest
