turbo project
hagasn
Re: turbo project
Postby hagasn » Mon Oct 26, 2015 1:10 pm
thanks Halden
i am the original owner of a 91 Isuzu pickup. the rebuilt motor was bored .040 over with a Calmini camshaft and gemini turbo kit with intercooler. power to the wheels is handled by a centerforce gold clutch.
hagasn
Re: turbo project
Postby hagasn » Sun Nov 01, 2015 1:38 am
she's up and running, whoot! now I just have to put some miles on her, 500 or so, and it's turbo time.
hagasn
Re: turbo project
Postby hagasn » Tue Nov 03, 2015 6:54 am
the motor is so quiet with the over bore pistons and ported head and intake I was expecting more of a performance gain. at cruising speed if you let off and get back on the gas she is definitely more responsive. I'm just impressed with fact that she's no longer leaks oil, fuel or water.
hagasn
Re: turbo project
Postby hagasn » Sun Nov 15, 2015 6:04 pm
it looks like i have a small weep from my oil gauge fitting. nothing like the leaks i've had over the past 25 years.
hagasn
Re: turbo project
Postby hagasn » Sun Nov 15, 2015 6:08 pm
i decided to do my first oil change this weekend just shy of 500 miles. i went with Castrol full synthetic 10W 30 and a K&N oil filter.
hagasn
Re: turbo project
Postby hagasn » Sun Aug 26, 2018 11:52 pm
almost three years and finally just now got around to turbo my truck :(
hagasn
Re: turbo project
Postby hagasn » Wed Aug 29, 2018 9:02 pm
the turbo install is in its final stages. we’re switching to a smaller electric fuel pump. the gemini fuel pump is just too large for what i’m trying to achieve which is reliability. we also ordered larger main jets for the Weber carburetor. drive safe
Re: turbo project
Postby JoeIsuzu » Wed Aug 29, 2018 9:14 pm
That's a really nice looking install.
hagasn
Re: turbo project
Postby hagasn » Wed Aug 29, 2018 9:18 pm
thank you
hagasn
Re: turbo project
Postby hagasn » Sun Sep 23, 2018 11:53 pm
i finally have the truck back. she still needs larger primary jets to make her safer. in boost my ARF reads 12.5. i barely step on the gas and she’s through the gears and @ 55mph :) i replaced the spark plugs with NGK’s but i need to increase the gap. she’s my daily driver so i’m doing my best to keep her in one piece. i’ll keep you posted
hagasn
Re: turbo project
Postby hagasn » Tue Dec 25, 2018 1:46 pm
update: after fouling a plug over a month ago i had her towed to a VW shop that specializes in weber carburetors. the AFR readings are safer and now she runs like a top :) with the day off i replaced the oil & oil filter this morning. drive safe
geforce
Isuzu vehicle(s): 91 pickup 2.3k
Re: turbo project
Postby geforce » Thu Dec 27, 2018 12:00 am
How does the truck feel with turbo? Did you put it on dyne for numbers?
I am looking to do a similar project soon in 2019.
